Go to Post Life isn't a set track: you have to go out and make your own path. - Greg Marra [more]
Unread 22-02-2006, 21:38
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
pic: 1351's Mark III
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 22-02-2006, 21:39
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: pic: 1351's Mark III
Heh, I like that tiny jungle of wires on the front. Cool flames too.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 22-02-2006, 21:44
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Is that a licence plate on the back?
Unread 22-02-2006, 21:50
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
do those flames help you go anyfaster ? How do 8 wheels work for you ?Great looking machine good luck !
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 22-02-2006, 21:54
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
8 wheel drive!?! Cool!
How well does it turn?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 22-02-2006, 22:02
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
does that cover(what is word) at the top of the robot used to aim the ball? that is one smokin hot bot...gotta love 8 wheels.
2005 - Waterloo Regional Highest Rookie Seed
2005 - Theory6 (1241) Top Rookie 2005
Unread 22-02-2006, 22:04
SpaceBoy2000's Avatar
SpaceBoy2000 SpaceBoy2000 is offline
Guy with Hammer in CAD cabinet
AKA: Michael Kwan or Frogger
FRC #0610 (Coyotes)
SpaceBoy2000 is on a distinguished road
My, just add metal plating to the side, and the thing will look like a tank. Very well done.
And by the lack of holes on the frame, I take it you didn't have weight problems, did you?
Unread 22-02-2006, 22:39
Electrical Engineer
AKA: Phil Baltar
FRC #1351
The turret on top gives us both elevation and azimuth control. You can't see it from this angle, but the entire turret rotates about the axis perpendicular to the ground. The deflection plate (I think that's what we're calling it) rotates forward and back on the axis holding the wheels. The ball contact surface is telescoping. You can see the fixed plate sticking out of the bottom. There's another plate behind it that goes with the moving part. The plate on top with slots is just structural. Elevation and angle are controled with globe motors. The wheel is powered by a big CIM, you can barely see it behind the elevation motor.
The drivetrain works nicely. The second wheel from the back is 0.25" lower than the others. Personally, I think it makes it rock a little too much.
The entire ball manipulation system is attached to the superstructure (the box frame). Early in the design phase, it was decided that the entire supersturucture (with ball manipulation system) would be removable for easier maintenance. I don't think we were able to make that happen though. It's still removable, but it'll take awhile. The superstructure is made of 1x1x1/16 6061 angle and is pop rivetted together, so it weighs practically nothing. And no, it won't break. The robot has already fallen on its back several times while coming down from the ramp.
The ball conveyors are ABS pipe with tubing as belts. The tube walking issue was fixed with the advent of Capture Rake Technology. You can see one of the capture rakes on the front bottom, right on top of the pipe. It's a bar with rollers on it to hold the belts in place.
A few days before the end of build, we had a scare with the weight. Someone didn't weigh the robot properly and we thought we were overweight. Most of that day was spent drilling holes and replacing steel parts with aluminum. After a reweighing, we discovered that we were underweight. The final number as of ship was 8lb under. That'll go toward strategically adding weight to fix the tipping issue on the ramp. The 1x1 tubing on the front that's acting as a front bumper is looking like a good place to fill with steel.
Version: 3.12
Unread 01-03-2006, 00:58
Electrical Engineer
AKA: Phil Baltar
FRC #1351
It seems that someone put together a video. The resolution isn't that great though. http://video.google.com/videoplay?do...40336671547203
Version: 3.12
Unread 01-03-2006, 01:05
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
i love the bot guys! does the front wheel look different or is it just that it's 1am? I do love the 8WD and i wonder where else i have seen that before. good luck on your comps and where you guys headed?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 01-03-2006, 01:26
Simple, elegant, effective. Two thumbs up.
Unread 05-03-2006, 23:28
Borgel's Avatar
Borgel Borgel is offline
Improbility clearly states...
FRC #1351 (T.K.O.)
Borgel is an unknown quantity at this point
Send a message via AIM to Borgel
Were going to Silicon Valley and UC Davis. Should be fun!
=2008: VP of Engineering
=2007: Coach of the drive team
-----38/48 SVR but we got congregational recognition due to odd circumstances
-----Quarter Finals at Davis
=2006: Joined T.K.O. #1351
-----Semifinals at SVR and Davis
-----2nd @ CalGames
=2005: Team 254
-----2nd in the Nationals
-----1st Silicon Valley Champions
-----2nd at UC Davis
=2000-2004: Volunteering as Field Reset
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
