Go to Post I’m not decently dressed for this picture.......I have no FIRST shirt, FIRST hat or FIRST pin anywhere on me! - Rich Wong [more]
View Poll Results: Do you have a turret?
No 56 47.86%
Yes 61 52.14%
Voters: 117. You may not vote on this poll
Unread 21-02-2006, 14:55
Umm Errr...
Poll: do you have a turret
Does your robot have a turret? Describe it. We have a pan/tilt mechanism. the turret can rotate around several times
1139 Alumni
Unread 21-02-2006, 15:07
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Re: Poll: do you have a turret
we have a shooter which has 180 degrees of rotation
Unread 21-02-2006, 15:16
in between teams
AKA: Luke Van Oort
We have a semi turret, it has about 70 degrees or rotation. However, it's sort of useless, since the drivetrain turns quicker and easier than the turret.
Team 1219: 2009 - Mentor
Unread 21-02-2006, 15:35
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
we also have a turret that can turn 180 degrees... we call it the "Kaboomer"
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
Unread 21-02-2006, 16:14
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
yes it goes 300 degrees hopefully we will not need it
shaun
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 21-02-2006, 16:59
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Yeah, our turret can make a 247 degrees arc, and has two chutes to accept balls. We use the turret to track the target and fire while moving. However, we can only pan. The trajectory and spin of the balls gives us a large range we can fire them over though.
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Unread 21-02-2006, 17:16
Elgin Clock's Avatar
FRC #0237 (Black Magic)
When the limit switch kicks in and reverses it, it goes about 330 degrees and then back and repeats as needed till it finds the target.
Unread 21-02-2006, 21:18
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Turret with slightly over 90 deg of rotation. Angle adjust in the pits. Three small Cims and 3ea 8" standard skyway kit wheels launch the balls. Tooth counter and software keep the cims at the same speed.
Unread 22-02-2006, 22:07
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Our robot has a turret that can go fast enough to get us in trouble. We can also change elevation.
Behold the power of SPAM.
Unread 22-02-2006, 22:26
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
We did... need I say more?
(If so... then we were a bit overweight.)
Unread 22-02-2006, 23:25
AKA: Dr. Brooks
no team (WRRF)
Why do you need to rotate around several times?
Why do you need a tilt mechanism?
Eugene
Unread 23-02-2006, 11:40
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
My team doesn't have a turret. (we can however turn, which hopefully will suffice in place of one)
--Insert Random Sidenote--
I just thought I should point out that this poll shows how weighted Chiefdelphi or at least the technical discussion community is weighted toward the high end of FIRST. I know for a fact that far fewer than 50% of all teams will have a turret. About 50% could very well be the number that can shoot, maybe less. The percent of those that have a turret is probably closer to 10-15%. That should leave the number of teams with a turret at around 5% probably.
--end of random sidenote--
Team Website
Unread 23-02-2006, 12:11
Originally Posted by eugenebrooks
Why do you need to rotate around several times? Why do you need a tilt mechanism?
Eugene
I can speak for us saying that we wanted to turn around multiple times as well for accuracy and shooting even more "on the fly" than we do.
Tilt is the ground to sky motion right? lol
If it is, As for tilt, it's not needed that much, but if your camera is locked in place for tilt you lose the target a few times on the floor (ie: going up the ramp, really close to the target, really far away.
We based ours on a set point we know or max shooting range is, and we're good to go, except for some of the instances mentioned above.
So far that is.. I don't know if a tilt is programmed in, and I just didn't see it.
Unread 23-02-2006, 15:08
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
We have a turret but we're probably not going to use it..
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Unread 23-02-2006, 15:16
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Ours can rotate -120° to 120° for 240° of total rotation.
Elevation control is accomplished by varying the speed of our cannon.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Camera Turret syncing FyreStorm90 Programming 0 28-01-2006 09:07
Turret or No Turret? Leo 1529 Technical Discussion 5 16-01-2006 15:47
universal goal designations : The poll Denman General Forum 11 08-03-2005 05:32
Poll: Role of Political Advertisement on ChiefDelphi SilverStar CD Forum Support 46 04-01-2005 17:01
idea: a semi-official coaches poll archiver 1999 8 23-06-2002 22:23
