Go to Post By the way why do all american's spell Colour wrong?!?!?!?!?!?!?!? - akoscielski3 [more]
Unread 23-02-2006, 01:10
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
Car Battery for post-season bot
i want to get a lot more speed and power on 4 CIMs and i want to use a car battery at 12v. Is this possible, and if not, can i use two EX batteries that we use at comps? I want 4 victors in it and dont know if the high AMP will cause the fuses to break. I also want to use one spike for a superstructure and run the compressor as well. Im planing on making a robot that can carry a heavy load, go fast, and also will have some cool superstructure that uses the actuators (i dont know what superstructure i will do, but know i want to use pneumatics). So, can anyone help and answer my questions about if its possible to use a car battery?
Thanks,
Eric
Unread 23-02-2006, 01:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Car Battery for post-season bot
A car battery will not give you more speed or power. Only more runtime. Also, I would not recommend it as they are not sealed gel cel type. Just get a giant battery from BB battery or your local battery store. It shouldn't cost too much. While you can use a car battery, I wouldn't due to spillage and safety concerns.
Unread 23-02-2006, 07:20
Eric,
Four motors or six doesn't matter if you don't get the reduction right to put the motors in a correct spot on their respective curves. A car battery will certainly let you run longer but you will be stressing the other components if you plan to run for a greater length of time then two or three minutes. Many teams are running very close to trip temperature on the breakers in a two minute match. You might have to redesign the electrical system if you plan on a longer run time. Whereas the kit battery is capable of several hundred amps in short bursts, a car battery is capable of 1000's under the same condition. The choice of that battery will change a lot of design criteria.
Unread 23-02-2006, 21:14
FRC #0599 (RoboDox)
well, i want longer battery life, that is good enough for me. My design was changed so i dont need extra power to the motors or go faster. I just need to have 4 motors running, a compressor, and one solenoid. So, i dont think ill over heat it with the EX battery we use now in comps. The motors wont be running when i use the solenoid to pressurize the actuator. I just want it to run a like 20-30 minutes minimum. I can add a lot of fans and heat sinks for over heating issues, and i dont understand why car batteries are not sealed. Well, how do i solve the amp problem?
Unread 23-02-2006, 22:49
I would be concerned about using the CIMs for a long amount of time. They do not have cooling airflow like the drill motors do. If I remember correctly the CIMs were designed for short use, something like raising the front trailer wheel on a camper.
Of course you can modify the motors for non-competition use, but I dont know if they even have the internal blower blades like the drill motors do?
You might want to look into something like an electric scooter motor, or electric wheelchair motors - something that is designed to be run continuously.
Unread 24-02-2006, 07:28
Eric,
Many car batteries are of the sealed type in a sense. Our are a gelled electrolyte not a liquid, which allows them to be used in any configuration including standing up. Car batteries cannot be used that way. We pulled a dead chalupa motor apart just last night. There are no fans internal, they are designed for short term light load uses. Fans will help a little but not much if you are running heavy loads for long periods of time.
Unread 26-02-2006, 16:42
FRC #0599 (RoboDox)
well, than is there a vey inexpensive motor/engine that can use a car battery? I can mount the car battery vertically, so there is not a problem there. The only problem is motors from what im gathering from this information. Oh, and the heavy load is a person, just to let people know. Im building a transportation device for a fundraiser for cancer, its call Relay For Life, and i want to build it so people can ride it around a track. I dont want gas engine. So, anyone know a cheap motor/engine that can work for my project? My max spending limit is like 100 bucks. But even that is very high. I wanted to use CIMs as myt team already has them.
Unread 26-02-2006, 16:47
You won't need 4 CIM motors for that purpose. If you are low on funds and want to use KOP parts, try using the FP motors with the stock transmissions. Those things are designed to cart people around.
Unread 26-02-2006, 17:12
I see this project getting very dangerous very quickly. Do not mount the car battery in any orientation other than horizontal.
Unread 26-02-2006, 17:58
FRC #0599 (RoboDox)
i can mount it in any direction. thats what i ment to say. i thought car batteries are mounted vertically, the battery orientation, not the mount. doesnt mater, i can mount the battery in 360x360x360 degrees. Any direction. I just need to modify the design to do that.
Unread 26-02-2006, 18:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
If you need more capacity, there are 'car batteries' that are sealed gell cells. Look at 'Optima' brand for one.
Unread 26-02-2006, 19:05
FRC #0599 (RoboDox)
yeah. thanks. now the engine/motor problem is my issue. thanks again for your guys's help.
Unread 26-02-2006, 20:41
I agree with Tom that two stock FP motors with transmissions are the best bet for you. You might need to follow up with a little different transmission (final gearing) to make up for the fact that you are driving bigger wheels than what the transmission is intended for. The kit battery might getyou around the track but a larger version of the same battery might be a better bet. You can buy new ones but there are various surplus shops around that might have used or surplus devices for sale. You will need to check around in your area. Since this is for charity, a local battery shop or car parts outlet might be willing to lend you or donate a battery of more capacity.
Unread 26-02-2006, 20:59
FRC #0599 (RoboDox)
Im thinking of the 8 inche wheels, only because our team uses a 6wd on our comp robots and use 6's for the wheels. We have a lot of 8 inch wheels. If those are not good, what will be. And, is there a way i can integrate 2 fp motors together. We have like 4 of them. Or will 2 be enough? A car battery will do the work, im almost positive from my research, so that will be the bigger battery.
Unread 26-02-2006, 21:21
I have seen people use old generators from car engines for small electric go-carts. Not alternators, it has to be a generator. VW bugs had generators up till around 72 or 73 (not sure the year they swithed to alternators).
There are two things that make these work well:
1. the are designed for a 12V application
2. they have a separate field winding that you can use to vary the speed. The stronger the field, the slower the speed (with more torque)
also they have fan belt pulleys already on the shaft. I would take a wild guess that you can get maybe 5HP out of one of these!
just to give you an idea, this is what they look like: the ground is through the metal housing, one connection is the armature, the other is the field
http://cgi.ebay.com/ebaymotors/VW-TY... 4644044QQrdZ1
Batteries Dave Hurt General Forum 21 29-12-2003 17:55
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
