Go to Post There is no safe place on a FRC robot. - IndySam [more]
Unread 18-02-2006, 18:48
Athena Athena is offline
FRC #1676 (Pi-oneers)
Athena is on a distinguished road
Camera Freezes?
Our team has been encountering a weird behavior of this year's camera. It will go through it's searching pattern and it does find the light. We have our cannon synced up with the camera's values. But sometimes the camera will completely stop all motion as if it was frozen. The servos motors are humming, but nothing is moving. Could this be a hardware problem? Or is there a problem with Kevin's Code? The only way we can reset it, is if we unplug our main battery, and the backup battery for 10 seconds. and plug in the backup battery FIRST and then the main battery. Is anyone having this problem?
Unread 18-02-2006, 23:17
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Camera Freezes?
Hmm...could we have a batch of intermittent controllers this year?
The symptoms sound very similar to mine, except I am running the 2005 IFI camera drivers.
See: http://www.chiefdelphi.com/forums/sh...threadid=44281
I hope someone knows something about this!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 19-02-2006, 21:25
FRC #0701 (RoboVikes)
Re: Camera Freezes?
We also get this problem... the camera puts the locked red light on , even though there is nothing in the viscinity and no matter what I do (block the lens etc) nothing happens~!
Team 701
Unread 23-02-2006, 09:14
Bill Becker Bill Becker is offline
#0596 (SciClones)
Bill Becker is on a distinguished road
Re: Camera Freezes?
Our camera also locks up sporadically with the red locked light staying on. It seems to reset if we open the main breaker for a minute or so. It seems to happen most often when we were trouble shooting auton code and reloading code and resetting the controller sporadically without powering down the robot. Our programming mentor thinks that it is happening when the camera doesn't initialize correctly??
Unread 23-02-2006, 09:20
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
Re: Camera Freezes?
We've seen the exact same problem. Same symptoms - red light is on, won't search even if I cover the lens, etc. This happened even with Kevin's default streamlined code. Just like someone mentioned, it seems to go away when we completely power down the robot for 10 seconds or so seconds. I hope the problem doesn't strike during a match.
Unread 23-02-2006, 10:10
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Camera Freezes?
I too have had this problem.
It's the backup battery. It's dying. When you do a "cold boot" the battery can often eake out enough power to run the camera again for a little while, and then it will "freeze" again after a bit. During testing I had to cycle the backup battery once every 15 minutes or so to prevent this.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 23-02-2006, 10:53
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Camera Freezes?
We had this problem last year, even with a full backup battery. We found that the best solution was, if we weren't recieving anything back from the camera for a while, to just re-initialize it. That always seemed to fix it last year.
Haven't had any troubles yet this year, but also haven't been playing with the camera very much yet.
Unread 23-02-2006, 11:35
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Camera Freezes?
I had the same problem but at a practice round the camera totaly quit i tried everything but it wouldn't start working. IFI is replaceing my camera because it totaly stoped maybe this is a known problem and IFI can help. I suggest having a backup camera at any compition.
Unread 06-03-2006, 09:35
nukem nukem is offline
nukem is on a distinguished road
Re: Camera Freezes?
The problem worsened at trenton, the camera spazes out when we disable it or put it into program state. The hard reset even stopped working and we had to rewire our camera(only the data port though). We've tried replacing the backup battery with new ones and sometimes that dosnt work. We are also using Kevins latest code so Im not sure what else we can do.
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
Camera shows no love to drive motors anifinder Programming 4 13-02-2006 10:31
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
