Go to Post My Worst Decision of the Week?? Reading this thread!! :) :) :cool: :cool: - BobC [more]
View Poll Results: Drive system or ground pickup
4 motor 2 speed drive with NO ground pickup 24 38.71%
2 motor single speed drive WITH ground pickup 38 61.29%
Voters: 62. You may not vote on this poll
Unread 22-02-2006, 00:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Drive system vs. ground pickup
Two speed shift on the fly drive system (5fps and 15fps), powered by 4 small CIMs and no ground pickup
Single speed drive system powered by 2 small CIMs (geared for 5fps) but with ground pickup
(in both situations the robot would have a very capable shooter and basket)
Which would you chose and why?
Unread 22-02-2006, 00:25
Steve Howland Steve Howland is offline
Many years, many teams
FRC #2473 (Goldstrikers)
Steve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond reputeSteve Howland has a reputation beyond repute
Re: Drive system vs. ground pickup
I'd have to go with ground pickup. Shifting is nice of course but given the options ground pickup seems to be a stronger advantage. Before the scrimmages I may have chosen the other one, but seeing so many loose balls on the field tips the scales IMO.
A basket is great for loading when on defense if you have a good human, but on offense you'd have to return to your side every time you run out of poof balls. The ground pickup, on the other hand, can be done on the far side easily and thus you probably wouldn't even need the high gear capability unless trying to outmaneuver another robot.
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I voted 4 motor, 2 speed drive. Being able to push other robots shooters, or corner goal bots is going to be key. As long as this robot can get its initial 10 balls into the goal, it can spend the rest of the time playing very aggressive defensive and making sure the opposing team can't score. Collecting balls off the ground while able to make or break a close game will not net you as many effective points as stopping the opposing team's shooter.
Of course there is always the we can do everything vote.
Team Website
Unread 22-02-2006, 08:06
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Go with picking balls up from the ground. I've never been a believer in human loading for the robots; the results of this week's pracitce competitions confirms my worries. 2 speed can be done without anyway (we've never had it).
If you are single speed though, might you need to be geared slightly faster?
Unread 22-02-2006, 12:07
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
we were able to keep 9 motors on our robot, including 4 drive cim's with 2 a speed shifter, without compromising any of our functions. We were 142 pounds at one point last week, but got her down to 119 by the end of the weekend . Coyobot VII can pick up balls dump them, shoot them, and has a slick drive system.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 23-02-2006, 13:27
Anubuss's Avatar
Anubuss Anubuss is offline
AKA: Brian Dixon
FRC #0085 (B.O.B. (Built On Brains))
Anubuss will become famous soon enoughAnubuss will become famous soon enough
Send a message via Yahoo to Anubuss
hmmm....
I think you need a few mor options for your poll. Like for example:
6 motor drive train, single speed (but has power limit, which can be turned off), and a ground pick up decive.
Unread 23-02-2006, 13:38
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Four motor - two speed.
Why? Because we could! We felt there'd be so many graizers that they'd spend much of their time getting in each other's way. By running back home to reload we can take a good run at the center goal and fire early and often with ground speed added to the muzzle velocity.
One way to defend that would be to pull out in front of us - got bumpers?
Unread 23-02-2006, 13:55
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Basically the question comes down to, "What's more important for defense? Pushing, or ball hording?" Though I'm tempted to say the second, I'd have to go with pushing. If you don't have pushing power, you can't stop any robots. If you don't have ball hording power, you are only vulnerable to floor picking robots. Judging from the number of teams that I assume are forgoing floor picking, (such as, say, The ThunderChickens) you are better off with a strong drive train to defend against them.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 23-02-2006, 14:03
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
I am slightly confused here, These options are not very separated from each other. What I mean is I have seen robots with 4 motor 2 speed drive trains that have ball pickup systems.
I would like to then choose the "both of best worlds" options.
But for the sake of hypothetical questions, I will go with the 4 motor 2 speed drive train.
Call me biased, I am a 4 year driver
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 23-02-2006, 14:25
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
The two speed drive sounds good, but is you gear "just right" you don't need two speeds. Pushing and speed can both come from a good designed drivetrain. Trying to find that design has and will take time for any team.
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
I don't believe this is a hypothetical question. I think Dave is trying to decide how to best use the limited resources they'll have available at their first competition.
--Madison--
...down at the Ozdust!
Unread 23-02-2006, 14:32
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
That is part of the reason I am confused. Is this in fact a "What do you think my team should do?" question? Having to do with a lack of weight to have all systems incorporated?
The question as it stands without any back round information is what I would call hypothetical.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 23-02-2006, 14:41
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Have you thought about using the Dewalt XRP Transmissions? Team 228 is using them this year; since we are only using two small CIMs and two Dewalt transmissions for our drivetrain, we had plenty of weight left over for a floor ball gatherer. The Dewalts on our robot are geared for a stump-pulling 3ft/sec, a moderate 8ft/sec and zippy 12ft/sec through the Dewalts.
Art Dutra IV
世上无难事,只怕有心人.
Unread 23-02-2006, 18:31
The Arizona Mentor
AKA: Andrew
From the othe posts made about their robot barely being finished, and from the picture, I gather that this IS a question on what they actually should do.
One thing that might assist this question; how good do you believe your human players are?
Unread 23-02-2006, 18:59
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
You can push people around all day but that doesn't get you any points. I'll go with 2 speed and a manipulator.
Students, what is your fantasy education system? Ken Leung General Forum 28 04-01-2006 09:20
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
Drive System Animation Project help is needed Brian Lesser Technical Discussion 4 12-10-2004 17:09
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
