Go to Post Honesty and Integrity is the key to success. - team4384 [more]
  #46   Spotlight this post!
Unread 21-02-2006, 22:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Got Weight?
we shaved about 40 lbs in 3 days.....
  #47   Spotlight this post!
Unread 23-02-2006, 10:16
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Re: Got Weight?
On the aluminum frame with the 1/4" holes in it, I used a Uni-Bit (one of those stepped-bits with wider rings for each size hole) to drill out EVERY hole to 5/16". We may need to go to 3/8", but for now this has worked.
Also, we drilled out nearly every peice of Lexan on the robot in cool designs and patterns.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
  #48   Spotlight this post!
Unread 23-02-2006, 10:18
AKA: Mike
Team Role: Driver
Re: Got Weight?
Originally Posted by ryan_f
Switch the air in your tires with helium.
For real?
Proud Eagle Scout
  #49   Spotlight this post!
Unread 23-02-2006, 13:18
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Re: Got Weight?
We took off about 20lb in 6 hours on sunday... it was quite the feat, but we learned some interesting things...
Like did you know that it takes 6 2"dia holes in 1/8" lexan to take out 0.1lb?
And that 3 1 1/2" bolts with their washer & nut weigh 0.1lb?
But it takes 50+ 1/2" holes in 1/16" alumnum to take out 0.1lb! Thats a very overworked drillpress!
We took out as much unnecessary support, bolts, lexan, steel plate, etc as we could. Ashley kept track of how much we had lost each half hour, and it was cool to see the giant bucket of parts & hacked off pieces in the end.
Now our poor little robot is all skin and bones!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
  #50   Spotlight this post!
Unread 23-02-2006, 13:26
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Got Weight?
It's a little to late for this tip I use, but I design my least favorite (aka risky, cute but not worth much, or complicated) components to be massive. That way I have one more excuse to get rid of them.
  #51   Spotlight this post!
Unread 23-02-2006, 16:18
MrForbes's Avatar
AKA: Jim
Re: Got Weight?
there is one of these puppies, with even more sizes, at the shop we were working in. If you have to punch a bazillion 2" holes, this is the only way to fly!
  #52   Spotlight this post!
Unread 23-02-2006, 16:26
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Got Weight?
Originally Posted by PVCMike
You'd be surprised with the speed holes. Last year we removed almost 20 pounds from ours, granted we had an 18' telescoping boom made of 1/8 aluminum box tubing, but still, it adds up, every little bit counts. And the thinner lexan is a good point, thinner everything will work really, we cut alot of weight a few years ago by going down 1 size in all the PVC tubing we used.
Also, smaller/less motors if you can, they weigh a bit.
Oh yeah, that lift was huge!
  #53   Spotlight this post!
Unread 23-02-2006, 18:29
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Got Weight?
if you bring your robot to a place with less gravity hmmm... lets say the moon for example you will be all set and plenty under weight.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
  #54   Spotlight this post!
Unread 23-02-2006, 18:42
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
Re: Got Weight?
It was mentioned twice before but my personal favorite tool in the Dremel. That means any screw that is too long gets the axe. Believe it or not, it does help. More so with the longer screws. Then again, our robot is all nuts and bolts so obviously, it would make a difference to us.
(Of course, we also swissed our robot. now we are comfortably under weight =D)
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
  #55   Spotlight this post!
Unread 23-02-2006, 18:43
BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
Re: Got Weight?
Zip ties are your friends. I can't tell you exactly how much lighter they are, but they sure are much lighter than steel.
We were so concerned about weight, we even used smaller zip ties in areas of little stress. I love zip ties.
I have a higher and grander standard of principle than George Washington. He could not lie; I can, but I won't. -Mark Twain
  #56   Spotlight this post!
Unread 23-02-2006, 19:19
Umm Errr...
Re: Got Weight?
Last year all of our speed controllers and electronics were held on soley by zipties. They never gave us any trouble.
1139 Alumni
  #57   Spotlight this post!
Unread 27-02-2006, 22:06
pyro20911d
Posts: n/a
Re: Got Weight?
An antigravity generator...oh and a drill
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Breaker Panel weight Emily Pease Electrical 4 24-01-2005 12:22
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
