Go to Post I've found that housework is more fun with power tools. - RogerR [more]
Unread 20-02-2006, 18:30
Prgrmin' Prgrmin' is offline
FRC #1721
Prgrmin' is an unknown quantity at this point
Send a message via AIM to Prgrmin'
GearTooth Sensor Destroying Hopes of Autonomous~!!!!!!
We have just hooked up our gear tooth sensors and finally started getting readouts. problem is there are 238 gear tooths and when we spin it around we get gear counts in the hundred millions. we have no idea of why the gear count is reading out like this. We are using the easyC to program the geartooth sensors. Any input on what to do or what might be causing this problem would be much appriciated.
Unread 20-02-2006, 22:36
Rombus's Avatar
Rombus Rombus is online now
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Re: GearTooth Sensor Destroying Hopes of Autonomous~!!!!!!
Hate to be the bearer of bad news, but i THINK the gear tooth sensors only sense direction, not tooth count.
http://www2.usfirst.org/2006comp/oth..._Operation.pdf
Unread 20-02-2006, 22:52
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
They definitely count. With Easy C, are you preseting them with zero?
Unread 21-02-2006, 19:48
Mark_K Mark_K is offline
FRC #1721 (Charette)
Mark_K will become famous soon enoughMark_K will become famous soon enough
The actual issue is the sample code included with EZ C. The printf display of the geartooth variable needs to be cast as a long. Otherwise the upper bytes will be filled in with random data that will make the count look incorrect.
Unread 21-02-2006, 22:59
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Actually, the gear tooth sensor should sense ONLY counts and give NO CLUE as to direction.
Unread 21-02-2006, 23:01
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Apparently, direction is possible. Just a little more convoluted.
See "GTS Counting" at http://www.chiefdelphi.com/forums/sh...threadid=44479
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Unread 21-02-2006, 23:26
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
well you should know what way you are turrning your motor . .so while the sensor may not know what way its going your code can.
if(motorPWM# <127)
gtscountdown():
if(motorPWM# >127)
gtscountup();
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 22-02-2006, 01:13
b_mallerd b_mallerd is offline
Programmer
FRC #1346 (Trobotics)
b_mallerd is on a distinguished road
Send a message via MSN to b_mallerd
Sadly, that only works in theory.
When you are stopping and your motors are getting a pwm of 127 the gears still spin for a little bit. I guess this wouldn't matter too too much but then your gear count wouldn't register during these times.
Unread 22-02-2006, 09:09
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
i have found that using the IR sensors they gave us a few years ago and a visual encoder will also give fairly accurate results and with very little programming. The code to handle all the stuff for our visual encoders is about 10 lines in total including overload handling and reset capability.
KK4KQO
http://voltair.us
Unread 22-02-2006, 10:59
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
I tried counting teeth (well sort of... I was using an optical sensor to count the number of revs of a shaft collar). I found the best way is to hook up the output of the sensor to an interrupt pin. That way when the sensor trips you increment your count (or decrement, depending on which way the motor was going last, use a tracking variable).
It's quite a bit more accurate than counting in the main loop as the IRQ time on those PICs is in the microseconds.
And, it's largely free.
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
Unread 22-02-2006, 11:43
Gdeaver Gdeaver is online now
FRC #1640
In my opinion the gear tooth sensors are a pain. A cheap alternative solution is to use the vex encoders in place of the gear tooth sensors. They work with the same Easy-C functions as the gear tooth sensors. They are also higher resolution. They can be added to the kit chassis and frame very easily. The KOP trans output shaft is tapped. A piece of threaded rod can be coupled to a piece of 1/8" key stock. Attach the encoder with a piece of 1/16" aluminum angle. You'll need a female by female PWM extension cable.
Works very well for going "x" feet during autonomous. Could easily be done Thurs. morning.
Unread 23-02-2006, 16:39
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
How do you interface with those in the code? Does it just give you a tick every revolution or something similar?
EDIT: 200th post! w00t!
Unread 23-02-2006, 20:27
FRC #1640
The Vex encoders give 90 counts per revolution. There is no direction info. The same easy-c function that is for the gear tooth sensor can be used for the Vex encoder. They are not of the Grayhill quality or cost. You wouldn't want to use one to measure the shooter wheel RPM but for measuring distance they're not to bad.
Unread 25-02-2006, 13:10
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
When using GTS do you have to use interrupts? Because we wrote a code using simple counters, it kinda works. It would be great if maybe someone could help us up and give like a sample code for the gts. Thanks!
www.sabrerobotics.com
Unread 25-02-2006, 13:16
Using interrupts really isnt as hard as it seems. You can even use the same code you've already written.. Just take the guts of your counter, put it in a function that whenever called will add one to the counter, and call that function in the ISR for whatever interrupt you choose to use. (I1-I3 are the easiest to get set up and running.)
