Go to Post For those of you who don't want to read a block of text: Respect the Tools. - Andrew Schreiber [more]
Unread 22-02-2006, 15:26
wkethman wkethman is offline
Team 118 Former Member
AKA: William Kethman
None #0118 (Robonauts)
wkethman is on a distinguished road
Send a message via AIM to wkethman
pot sensor selection
does anyone recommend a pot sensor that i can use for a control module to know the exact position of a smaller control to control the robot. i saw it done a few years back where they have a small mockup of their bot and whenever itw as moved the real bot moved accordingly and i want to apply it to a testing module for another project. thanks guys
Unread 22-02-2006, 19:26
jzampier's Avatar
jzampier jzampier is offline
Finger Lakes Regional Staff
AKA: Jeffrey Zampieron
no team (-)
jzampier is on a distinguished road
Send a message via AIM to jzampier
Re: pot sensor selection
What kind of pot are you looking for? (I mean I know you need 100kOhm for the RC/OI) Single Turn or Multi-Turn??
Pots
This company has some nice ones that digikey sells.
These might do it as well.
DON"T BUY AUDIO POTS!!! (they aren't linear and will do strange things w/ the OI/RC)
"Put your hand on a hot stove for a minute, and it seems like an hour.
Sit with a pretty girl for an hour,
and it seems like a minute. THAT'S relativity." -Einstein
First Resume: (If I can remember)
2001 NJ Regional
2001 Championship
2002 NYC Regional
2003 OH Regional
2003 Championship
2004 OH Regional
2005 Finger Lakes Regional
2006 Finger Lakes Regional (yes!)
Unread 23-02-2006, 00:05
Take a look at the second link above. That page has a variety of pots but I would stick with those that have a 1/4" shaft diameter with a long shaft If you are using it for operator control you will want some method of supporting the shaft so that a overzealous operator doesn't bend it into a modern object d' art. Stay away from mutliturn pots or those with screw driver shafts. You need 100K for the OI interface wired as shown in the OI manual. The OI monitors the it's inputs and if it believes a joystick has become unplugged it sends a PWM 127 to the appropriate RC channel. Similar pots are available from Mouser and some are available at Radio Shack. Be advised that not all stores keep the same stock in the store.
Unread 23-02-2006, 10:56
Happy Birthday! Sara Milton Sara Milton is offline
AKA: Smilt
FRC #0237 (T.R.I.B.E)
Sara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant futureSara Milton has a brilliant future
Send a message via AIM to Sara Milton
We used these pots last year. They aren't that expensive either.
We got them from Radio Shack Part # 271-092
http://www.radioshack.com/product/in...tId=2062287&cp
You will want to call ahead of time to see if they have any in stock.
Unread 23-02-2006, 23:04
DonRotolo's Avatar
Back to humble
FRC #0832
The OI needs 100k pots. There are a variety out there, be sure to choose Linear or "B" taper. Mostly you will want to choose a pot for its mechanical configuration, electrically they are all (nominally) the same. (More expensive pots are more reliable and have a longer life, but the $1 "Alpha" brand pots at Mouser are OK too)
On the robot, try for 2.5 K or 5 K ohm pots, the RC reads those best.
Don
Unread 24-02-2006, 11:28
thanks guys. unfortunately radio shacks in new orleans no longer exist but that helps so that i can order online thanks alot, does anyone know if any team has extra vic's that i can purchase. i used to be in first but i go to tulane university and because of funding (hurricanes) the school can't afford much for projects and I am having to foot the bill. any team that might be able to help me would be great
Pwm and pot Zoom Programming 6 29-01-2006 18:47
Should I use a Pot or an encoder, and how? mallot1243 Programming 4 18-11-2005 02:25
Shallow Pot Magnets on Tetra Coachmac Rules/Strategy 4 18-01-2005 12:15
pot help chrisw Technical Discussion 1 25-01-2002 21:10
