Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Unread 21-02-2006, 16:45
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
pic: Scorpio - 166 - 2006
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 21-02-2006, 16:53
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Re: pic: Scorpio - 166 - 2006
Tis the year that 166 wins BAE????? Looks AWESOME guys!!!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 21-02-2006, 16:55
Nate Laverdure's Avatar
FRC #2363
Looks awesome.
What brand wheels are you using (and/or did you make those omnis)? Are you using FIRST trannys or are you using the same 2-speed one you used last year?
How long does it take the shooting wheel to spin up? Can you vary the speed to change the height of the ball's trajectory?
What material is on your rollers? Mousepad works superbly well. We used mousepad and pneumatic tubing.
I'd like to see it if I get back to Merrimack anytime soon.
Check out 612's cool pictures in our gallery.
Unread 21-02-2006, 19:16
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
166 that looks awesome, too bad I wont be at BAE to see it up close. Are there more pics online somewhere?
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 21-02-2006, 20:51
Originally Posted by Nate Laverdure
Looks awesome.
Not sure about the rear red wheels, but we bought the front two wheels from Andy Mark.
Unfortunately, it takes quite a while to get the launch wheel going. I'm thinking of ways to get that better while still being underweight
The rollers are all aluminum except the top which is wrapped in pipe insulation so it has a wider diameter for giving the balls enough push to get them into our storage, it's very similar to mousepad material
We didn't use the two speed transmissions last year, but we are this year
Haha, thanks
Unread 22-02-2006, 22:59
Gundamx92000's Avatar
Gundamx92000 Gundamx92000 is offline
AKA: Ross
Gundamx92000 is on a distinguished road
Send a message via AIM to Gundamx92000 Send a message via Yahoo to Gundamx92000
Smile Re: pic: Scorpio - 166 - 2006
Oh cmon that wheel gets up to speed pretty quick considering the software behind it to make it maintain constant speed. Also you cant quite tell from the picture but we have a spiral holding tank made of aluminum rods and a core with a helical hole patern. the holding tank alone holds 15-16 balls, plus whatever floats above that are held down by the "net" which is actually made of a few pinnies that Mr. George had I guess.. who knows if they're used... on top of that is however many balls we fit in the gatherer. I'd estimate that at max capacity we could probably hold.. oh maybe 20-25 balls? we also have a rather nifty crosshair system that allows the copilot to more precicsely aim the shooter. And to assist the co-pilot we have a revolutionary "flex drive" to aim the two rails a bit in either direction. the two speed tranny works great, and its been tweaked since you and Ii used it in '03, nate. high gear is higher and its a little bit lighter. We also made some really cool feet but due to weight we didn't install them.. and those omni wheels really do dig into the carpet for superior traction in the drive diection with low friction in the turning direction so it drives rather nicely. See you guys at Nationals!
oh, you can find more pictures of the robot and the team here
http://public.fotki.com/CrazyKate/fi..._20/page7.html
Ross Martin
Team 166
CHOP SHOP
"No Ross, I am not going to wear a kayak..."
"Yeah... but then we'd have to clean the shards out of the lawn..."
Unread 23-02-2006, 11:51
FRC #2363
Good to hear from you, Ross. So you can't change the speed of the shooting wheel to increase or decrease range, then.
The crosshair system sounds intriguing. How does it work? Do you use video feed from the camera to create a display on the OI?
The robot looks a lot like the Patriot. How much of an influence was it when you were designing?
See you soon.
Unread 23-02-2006, 16:44
See you soon.
Software didn't get enough integration time to get the wheel moving at different speeds. So, they'll be working on that at the regional
It's not video feed. It's a graphic cross hair on the laptop we are bringing to the drive station. There is a little box that indicates where the goal is in relation to where the shooter is pointing. If the green dot is where the two hairs meet, then we will hit the target.
There was some Patriot influenced design. The storage was originally the same idea Patriot had with the angled shelves. After mocking that up we found that the balls easily got stuck and we changed it to a spiral.
Unread 23-02-2006, 18:22
FRC #2363
Willing to trade software? I've got something intruiging up my sleeves... I'll give you a hint- it involves the number 0.000062000124. Any guesses?
Unread 23-02-2006, 22:20
AKA: Ross
thats close to avagadros number but severly decreased by factors of 10. maybe the refresh time on a certain sensor? i dunno....
Ross Martin
Team 166
CHOP SHOP
Unread 24-02-2006, 07:51
FRC #2363
Nothing to do with Avagadro (I had to google it to remember what avagadro's number was) or sensors. The refresh time for our code is 40x per second, or 0.025 secs.
So, do you care to trade?
Unread 24-02-2006, 08:09
AKA: Mongo
will someone on 166 please forward my name and email to someone at BAE or Nashua. I do not have a contact for anybody, and would love to get back with my former team as a mentor.
Thanks,
Greg Perkins
gregperkins134@gmail.com
pic: SPAM's 2006 robot buss Robot Showcase 10 22-02-2006 18:49
pic: 2006 FL Scrimmage + Video Tim Arnold Robot Showcase 10 19-02-2006 22:51
pic: ThunderChickens 2006 Masterpiece of a Robot Paul Copioli Robot Showcase 7 19-02-2006 10:02
pic: Screws Loose 2006 Robot: Top Gun Rick TYler Robot Showcase 2 18-02-2006 21:08
pic: Team 20 2006 Robot John Neun Robot Showcase 18 17-02-2006 01:24
