Go to Post Push the envelope a little, but not too much. There's a difference between being on the cutting edge and being on the bleeding edge. - cadandcookies [more]
Unread 23-02-2006, 16:12
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Horizontal Shooters
I was just curious how many other teams have horizontal style (wheel(s) left to right) shooting mechanisms, mostly for center goal scoring.
An example of ours can be seen here:
http://www.chiefdelphi.com/forums/sh...threadid=44555
I've seen alot of 1 wheel shooters, or even 2 wheel but upright.
So, why did you choose the arrangement you did?
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 23-02-2006, 16:56
Re: Horizontal Shooters
We didn't go the softball-shooter route, but if we had, we'd very likely have used a vertical wheel to accelerate the ball from underneath. Backspin on the ball should help give it "loft", making the trajectory somewhat flatter than a plain parabola. That increases both the maximum range and the amount of time it spends at the height where it can make it through the center goal.
Unread 23-02-2006, 17:02
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
You can see we went with the same stye horizontal shooter.
as seen:
http://www.chiefdelphi.com/forums/sh...453#post459453
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 23-02-2006, 17:04
Sachiel7's Avatar
AKA: Shayne Helms
Yay! We're not alone...
Anyone else have pics?
I'm not sure if anyone got video of our shooter...we'll have to see if we have any and can post it...
-=Sachiel7=-
Unread 23-02-2006, 17:19
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Team 116 has a horizontal-style shooter as well (at least, we think it is still on the robot - it seems we had to go a little nuts with the Sawzall during the last three hours before the robot went in the crate and remove several subsystems, due to some team members being slightly uncomfortable with our 147 pound weight - without the battery or bumpers! <sigh>). Anyway, we do (did?) have a horizontal shooter, and it was working very well the last time we saw it. During testing, it was launching balls half way across my back yard (at 11:30pm - I don't even want to know what the neighbors think any more...). We will see you in Richmond, and can compare notes!
-dave
Unread 23-02-2006, 17:30
CraigHickman
Posts: n/a
Our team went with a vertical shooter after much prototyping. However, due to the fact that the balls have topspin coming out of our shooter, our range is slightly decreased. A plus side is our shooter shoots the exact same spot every shot. We may be short range, but we make every shot.
Unread 23-02-2006, 19:01
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
We chose a vertical shoote, for two primary reasons.
First: It gives us a backspin, allowing us a greater range, and
Second: With horizontal shooters, if the speed of one wheel/drum is slower than the other, then the ball will have a wicked sidespin. With a vertical design, we didn't have to worry about the sidespin effect, and are getting 8-9 balls out of 10 into the goal.
Unread 23-02-2006, 21:02
John C's Avatar
John C John C is offline
FRC #0075 (RoboRaiders)
Team Role: Driver
John C has a spectacular aura aboutJohn C has a spectacular aura about
Are team went with a two wheel side by side design. We did a lot of testing on different options. Having the wheels up and down did not seem to have much of a difference from having them side by side. We went with side by side because it fit into our design better. To achieve good accuracy you need to make sure that the wheels are spinning at the same speed.
Unread 23-02-2006, 23:12
shamuwong's Avatar
shamuwong shamuwong is offline
pretty little words.
AKA: Mike Wong
FRC #0469 (Las Guerillas)
shamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to behold
During testing, we found that the balls were not uniform in density. One half of the ball would be heavier than the other, making it hard to get an accurate spin on the ball. Also, the balls vary in weight and density from color to color. That was one of the factors we considered when designing the shooting mechanism.
ΜOΛΩΝ ΛΑΒΕ!
attending: great lakes regional, west michigan regional, detroit regional, the championship
Unread 24-02-2006, 01:14
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
We went with a dual wheel, side by side, vertical shooter. We get good range with the back spin. From 17 foot or less we are deadly accurate. At a greater distance we are probably 90 accurate.
We can also shoot the balls at an angle to the goal.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 24-02-2006, 08:12
GaryVoshol's Avatar
Cogito ergo arbitro
We went with dual side wheels, mainly for height. We have sensors to tune the wheel speeds.
2 Shooters??? Jon Jack Robot Showcase 14 26-01-2006 20:00
Female Shooters JulieB Championship Event 29 28-04-2004 16:47
specs for the horizontal bar Gary Dillard Rules/Strategy 0 05-03-2004 14:50
horizontal rule Brandon Martus CD Forum Support 5 22-09-2003 23:20
dimensions of horizontal bar archiver 2001 7 23-06-2002 23:32
