Go to Post Transparency is the sign of BAD LARD! - ExcuseBoy [more]
Unread 24-02-2006, 14:30
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Re: Scrimmage Video?
Originally Posted by robosapien
Thanks for the compliments, but, well... Adobe Premiere (link is to student purchase site) is a 'prosumer' product. It doesn't come on the cheap (all though premere elements may do just the job) and has a pretty high learning curve. It is great software to know how to use though, and integrates well with other Adobe products.
I have never used ArcSoft products, but I know you can put together images and video (very basic though - rather limiting) with the freely available Microsoft Movie Maker. My friends have used it with some basic projects and the results are very good for a free program. It includes some basic transitions and effects, but again, it is limiting. The Premiere Elements program I mentioned earlier may be the same way, I have never tried it. CNet gave it a 7.8/10 ("Pros: Imports video from different devices; improved interface; better DVD-menu options; Dolby-audio support" "Cons: Sluggish performance; can't import HDV or export to MPEG-4; sub par support"). I would suggest giving Windows Movie Maker a try before you buy anything. A brief guide for it is on Microsoft.com's expert section. I would recommend using the DVD software you already have and know how to use for the DVD burning part (after you edit with WMM).
With the kickoff music, as Andrew Blair says, its Canned Heat.
Good luck with your film productions! The main thing I have learned with making movies is to always try to do something better with more features, in a shorter amount of time. Adding transitions to menus, for instance, the first time took me 3 weeks to figure out and design (using photoshop and premiere - school interruptions included). Don't give up and don't release crappy work that you will regret being under your name later (but don't let that hold you back from starting in the first place)!
EDIT: You can also do some very simple DVDs with Nero 7. (Great for stuff you don't want to spend too much time on presentation before the actual feature - such as showing the scrimamge video above to other members of our robotics team)
Thanks for everything Is the free play website legal?
Thanks
Unread 24-02-2006, 17:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Thanks
Yes, Freeplay music is free and legal depending on your use of it. I think FIRST would be considered "Educational, Non-Commercial use (limited to student use on school grounds and classroom - non broadcast) " under their terms of service. But then again you may be considered "Non-Profit (most)" and in that case you need licensing. The division between the two may be a little blurry depending on your use. Now I know why I am not a lawyer.
http://www.freeplaymusic.com/licensing/termsofuse.php
Art Dutra IV
世上无难事,只怕有心人.
Unread 25-02-2006, 09:28
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Rochester Rally
Unread 25-02-2006, 10:41
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Koko ed, i am getting an error trying to open up the Rochester rally. is it just my computer? thanks for your help.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 25-02-2006, 10:56
AKA: Matt Starke
never mind, it started working. sorry for the waste of a post.
Unread 27-02-2006, 16:08
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
i have alot of video of the utc scrimage but i was on vacation so i did not get much time to upload it B/c its at school i will wait till next meating to post the video
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 27-02-2006, 19:08
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Well.. to keep everything together, I will quote my links from the other thread...
Originally Posted by Ted Boucher
More videos!
Field/06 FIRST gear:
http://www.zippyvideos.com/482313575...crimspeedchkr/ Shooter Speed Checker
http://www.zippyvideos.com/612436854...scrimnewramps/ New Ramps
http://www.zippyvideos.com/109628349...riversstation/ Drivers Station Overlook
http://www.zippyvideos.com/933742940...kenfieldlight/ Broken Field Light
http://www.zippyvideos.com/253426460...scrimradiosv1/ Radio Tower
http://www.zippyvideos.com/905003346...cscrimvictory/ The End of the day
Matches:
http://www.zippyvideos.com/864884867...6/utcscrim4v1/
http://www.zippyvideos.com/9149129013897016/utcscrim5/
http://www.zippyvideos.com/7694458803897106/utcscrim6/
http://www.zippyvideos.com/1735729733897156/utcscrim7/
http://www.zippyvideos.com/1987418053897206/utcscrim8/
http://www.zippyvideos.com/9187484443897446/utcscrim9/
http://www.zippyvideos.com/9390238043897496/utcscrim10/
http://www.zippyvideos.com/9402291023913706/utcscrim11/
http://www.zippyvideos.com/7601922863913876/utcscrim12/
http://www.zippyvideos.com/4577345903913946/utcscrim13/
http://www.zippyvideos.com/5200337283914006/utcscrim14/
http://www.zippyvideos.com/6326766563914056/utcscrim15/
http://www.zippyvideos.com/8985802253914126/utcscrim16/
http://www.zippyvideos.com/9056601493916766/utcscrim17/
http://www.zippyvideos.com/2513860583916806/utcscrim18/
http://www.zippyvideos.com/8778293113916836/utcscrim19/
The video numbers do not correspond with the match numbers.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
Unread 11-03-2006, 20:25
aksimhal's Avatar
AKA: Anish
Thanks
Also, I'm wondering how to remove the score board that appers every 5 minutes on the Windows Movie Maker video, I transfered.
Thanks
1604 Harmony Hurricanes promo video Barry Bonzack Robot Showcase 11 04-03-2006 18:56
pic: 2006 FL Scrimmage + Video Tim Arnold Robot Showcase 10 19-02-2006 22:51
Video: Cyber Blue 234 Late Night Programming Video JAH Robot Showcase 6 13-03-2005 00:34
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Good video footage miketwalker General Forum 0 28-03-2002 17:14
