Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
Unread 24-02-2006, 15:26
dwc309 dwc309 is offline
FRC #1552
dwc309 is an unknown quantity at this point
Talking porting camera code to 2005 bot controller
We'd like to port the camera code to the 2005 controller so that we can work on it during the upcoming windows starting March 6. I've started that, but ran into the camera serial port shtuff. Any suggestions on the "easy" approach? There has to be code for the ttl serial port for the 2005 controller, right? Is is better to modify that or squeeze the 2006 shtuff into there? Any other suggestions?
Unread 24-02-2006, 16:32
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Re: porting camera code to 2005 bot controller
I believe the only thing you have to do is change the target microprocessor in MPLab and change the library and linker files as specified in one of the text files included with the default code. I ported code the other way (2005 controller to 2006 controller) early in build season and I don't remember having to change anything else.
Behold the power of SPAM.
Unread 24-02-2006, 23:56
Kevin Watson's Avatar
La Caņada High School
FRC #2429
The code should run just fine on the 2005 RC. Follow the directions in the "Using_Last_Years_FRC.txt" file that I included in the build directory.
-Kevin
Kevin Watson
http://kevin.org
Unread 27-02-2006, 14:28
FRC #1552
Talking Re: porting camera code to 2005 bot controller
There are still 3 errors. It looks like a struct definition member needs to be defined. The errors are below.
C:\Microchip\First_Code\fVersion_05\serial_ports.c :387:Error [1205] unknown member 'SENDB' in '__tag_100'
C:\Microchip\First_Code\fVersion_05\serial_ports.c :387:Error [1131] type mismatch in assignment
C:\Microchip\First_Code\fVersion_05\serial_ports.c :481:Error [1205] unknown member 'ADDEN' in '__tag_4'
C:\Microchip\First_Code\fVersion_05\serial_ports.c :481:Error [1131] type mismatch in assignment
C:\Microchip\First_Code\fVersion_05\serial_ports.c :520:Error [1205] unknown member 'SENDB' in '__tag_8'
C:\Microchip\First_Code\fVersion_05\serial_ports.c :520:Error [1131] type mismatch in assignment
Unread 28-02-2006, 07:01
The Lucas's Avatar
CaMOElot, it is a silly place
Clean your intermediate (.o files). Project menu -> Clean or manually delete them. That works sometimes, usually after you make many changes and MPLAB is too stupid to update the files.
Robot Inspector
Unread 28-02-2006, 10:37
FRC #1552
Thanks for taking the time to help but that was not it. I tried it, but I had started from a fresh directory with no .o files in it. Either way, the error occurs.
It appears to be a struct defined in the 18f8722 chip and not the 18f8520 chip, more to research I suppose. I was hoping to have it ready for the kids when our next window occurs, but I suppose that will have to wait til then.
Unread 28-02-2006, 19:16
Electrical Engineer
Rookie Year: 1995
Be advised that my students followed the directions in the "Using_Last_Years_FRC.txt" file and it worked just fine.
Mike Betts
As easy as 355/113...
2006 Camera identical to 2005? de_ Programming 6 23-01-2006 03:28
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
Trying to import Camera code into program without. Kingofl337 Programming 1 18-02-2005 00:43
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
