Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 23-02-2006, 21:30
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Finding servo location?
Just as a quick question, seeing as I never got to test my code, would getting the location of the servo be as simple as
printf("Servo Location is... %d\r", pwm01)
or would I have to do something more to find where it is betweeen 0 and 255...?
Unread 23-02-2006, 21:38
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Re: Finding servo location?
that works
Unread 23-02-2006, 22:10
printf("Servo Location is... %d\r", (int)pwm01)
Unread 24-02-2006, 16:21
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
First of all what are you trying to do? If you are setting a value to pwm01 and then printing it out later, this should work. However, you can't physically read the current position of the servo motor. Neither the hardware or software support this.
Behold the power of SPAM.
Unread 26-02-2006, 19:18
rodgadashruba rodgadashruba is offline
FRC #0611
rodgadashruba is an unknown quantity at this point
wait so there is no way to tell where the camera, like to read what position the tilt servo is at?
Unread 26-02-2006, 19:20
bush's Avatar
AKA: Aaron
You can. Just read the value of the PWM - in Kevin's code, the position is in the variable TILT_SERVO and PAN_SERVO
Unread 26-02-2006, 19:21
If you are using the onboard motor control (PWM) to move the camera servos, you can put that printf right after the line that modifies that outputs value (make sure it is before the PutData !!)
If you are using the servo controller on the camera, you will have to ask the camera for what the current servo value is.
Unread 26-02-2006, 19:47
FRC #0611
well i tried that in user routines, in the default code funtion. the code compiles just fine but when i add int he comman
int testTest = PAN_SERVO ;
or
static int testTest = PAN_SERVO;
i get syntax errors
is there a way to access these varible outside of tracking.c?
Unread 26-02-2006, 20:05
Bharat Nain's Avatar
or
i get syntax errors
Paste the whole file where you put this line of code.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 26-02-2006, 20:24
FRC #0611
alright its attached
its down where it is commented out for the aim up code
Unread 26-02-2006, 20:44
Don't you have to declare the variable andrew OUTSIDE the routine?
That might be it, then again, I could be wrong.
(code trimmed out to point out lines in question)
void Default_Routine(void)
int shooter;
// aim up code... WOOT
// ok so find the value of pwm1 to line up the robot.. should be easy enough
static int Andrew = PAN_SERVO;
Unread 26-02-2006, 20:48
FRC #0611
I thought that was it but shooter is declared..
i will try it out tho
Unread 26-02-2006, 20:55
FRC #0611
wow alright.. so turns out i fail at remembering basic C...
had to declare Andrew at the top of default routines..
Unread 26-02-2006, 21:31
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Keep in mind this tells you where the servo is being commanded to go, not where it is, in most case they're synonomous, but if you're caught on something, or doing a lot of tracking this value could introduce lag which creates oscillations, making it worse, feedback loops, a constantly increasing error, all kinds of bad stuff. Just remember thats where it's trying to be and 98% of the time it should be there.
Matt Krass
Unread 26-02-2006, 21:45
Just out of curiosity, is there a better way, then?
Finding the *final* Servo Center values? Andrew Blair Programming 2 22-01-2006 18:02
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo command confusion?!?!?!?! [527]phil Programming 9 15-07-2005 20:10
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
