Go to Post “Hey, why are those numbers showing, it must be a game hint!” Listen, please – it’s not a game hint. Our game hints typically start with something like “This is a game hint!” - Frank - pwnageNick [more]
Unread 24-02-2006, 17:37
Mike Nawrot's Avatar
Mike Nawrot Mike Nawrot is offline
NAwrot (a.k.a. jub jub)
AKA: Mike
FRC #0011 (MORT (Mount Olive Robotics Team))
Mike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really nice
Send a message via AIM to Mike Nawrot
How do you shift??
I've started prototyping a 2-speed gear box for next year, which i may expand in different directions, be it more speeds, or brakes, or other functions, it doesn't matter. I need to know how most teams decided to shift gears. Obviously, the most popular solution is a pneumatic cylinder, but I am looking for an alternative, because I do not find the need for pneumatics if they are not being used anywhere else on the robot. I've looked at electronic linear solenoids as a replacement, and i found one type that has the equivalent force of a 7/16 bore pneumatic cylinder at 60 psi. Two problems. 1: the model i was looking at can only be on continuously for 1 minute at a time, which may be an issue if we're in low or high gear for more than a minute at a time, and 2: I'm not sure if linear solenoids are legal in FRC. I will continue researching various linear solenoids, but in the mean time, i would like to keep an open mind about shifting mechanisms. Also, if you find any useful information about linear solenoids, please leave me a link. Thanks.
"Its not just good... its good ENOUGH..." "Talk to me in two weeks" "It has to be done by Sunday" "Let me tell you a little something about FLL..."
"Physics don't apply on MORT robots" "What's today's roofigog?!" MIT class of 2012
Unread 24-02-2006, 17:49
Re: How do you shift??
Solenoids have been consistently put in the "not legal" slot for many years.
Consider using a servo, or a motor driving a cam, or a geneva wheel connected to a rack and pinion.
Unread 24-02-2006, 18:42
AKA: Mike
Hmmmmmm.... thats very unfortunate.... Out of curiosity, why are they illegal? I guess I'll have to look at the servo idea.... Of course, another question, do you really need alot of force to hold a dog gear in place? If it is a low force application, which I am pretty sure it is (if you're hit hard enough, you may stall the motors.... which is next to impossible with CIMs... from what i understand..... but the force on the dog gear is perpendicular to the motion of the shifting mechanism... so not much force can be applied) I can easily shift the dog gear with a servo..... Although I easily solved the problem, your suggestion of a servo made me think, so thank you. But i am interested in what other things people will say. Thank you, again. Time to update some CAD drawings.......
Unread 24-02-2006, 18:54
in between teams
AKA: Luke Van Oort
Why not attempt to make something that doesn't shift in the normal sense, like a CCT (Crazy Chicken Transmission - A CVT style device the Thunderchickens thought up)?
Team 1219: 2009 - Mentor
pic: 2 speed, shift on fly CD47-Bot Extra Discussion 4 11-10-2004 11:46
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
To shift or not to shift? sanddrag Technical Discussion 61 15-04-2003 22:56
Need help in creating program to use servo's to shift drive archiver 2001 19 24-06-2002 00:35
