Go to Post Redfoo is actually a really awesome guy. He discussed the future of engineering and talked about C programming with our software team. - SM987 [more]
Unread 25-02-2006, 00:12
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Tx/Rx pin layout?
I'm trying to connect the CMUCam from the FIRST kit to my vex controller. I know this is possible by connecting the TTL conveter for the camera to the TX/RX, but i don't know what pin of the three carrys data.
Unread 27-02-2006, 10:18
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Tx/Rx pin layout?
If you compare it to the standard input pin RED is +5, Black is Ground, White is RX/TX. If you are using a CMU CAM plug directly into its TTL port and skip the adapter board.
The easiest way to complete your "MOD" is to kill a pair of bump/limit switches
and use the cable to make an adapter.
VEX inputs Andrew Blair FIRST Tech Challenge 22 31-05-2006 18:17
Encoders and putdata theycallhimtom Programming 3 09-02-2006 19:24
Attatching an axel to a wheel Zoheb N Technical Discussion 36 12-12-2005 13:43
joystick pin layout fred Control System 1 29-01-2005 14:02
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
