Go to Post Surely any group of rational human beings (which FIRST seems to attract) can work this out. - Billfred [more]
Unread 24-02-2006, 23:16
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
pic: Mr. Cellophane
Unread 25-02-2006, 00:12
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: Mr. Cellophane
Hey, nice to see the robot from the other side of the school district.
So you shoot into the corner goals, eh? How exactly does that work? It seems hard to shoot balls into the corner goals, considering how short the slots are. I have trouble throwing a poof ball in from 20 feet away. I guess I could wait for the details until the Silicon Valley regional, but I'm not that patient.
Very nice helix storage system. And it says you have a four speed transmission! DANNNNNNGGGGGG dude. Good luck and see you guys at SVR in a couple of weeks.
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 25-02-2006, 00:16
Be sure to tell us all how the 4 speed turned out. I can see the shift box, but where is your motor input? I only see one CIM motor sitting to the left of it.
Anyway, we decided 4 speeds was a few too many (it would be PIMP with the autoshifter working, but ours seemed to shift every time we moved the sticks), so we went down to a 2 speed blind shifter (same thing, minus the last 2 reductions) and man, does it run ten times better..
Unread 25-02-2006, 00:42
Nuttyman54's Avatar
Mentor, Tactician
The shooter wheel is actually a 2" roller mounted directly one a CIM. It's hidden by a piece of pressboard mounted about on ball-length from the first ball in the queue. The purpose of the shooter is to allow us to get them into the corner goals w/o having to drive all the way up to them. It hasn't been mounted yet, but we hope to add an IR distance sensor to automatically adjust the wheel speed and get the shots in. We tested with a 1/2 width plywood goal and made 11/13 shots within 3 seconds
As for the transmission, it was orignally designed for the drill motors, so we did some pre- and post-gearing on it to get it back down to reasonable speeds. The CIM you see next to it is geared 1:2 into the transmission input, then geared 1:2 to a stepper shaft mounted above the wheels, and then 1:3 to the wheels. The We got the automatic shifting to work using a 4-slot home-made encoder wheel (mounted on the output shaft). We found the intersection points of the efficency curves (from 33's excellent white paper) for the different gears and applied a histeresis to keep them from shifting too quickly. It will also never go past 3rd gear unless the driver holds both triggers and forces 4th gear.
Unread 25-02-2006, 13:53
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
how many balls can Mr Cellophane store?
Unread 25-02-2006, 14:38
Nuttyman54's Avatar
Mentor, Tactician
about 30 or so in the hopper itself and then another 4 (maybe more) in the pick up mechanism.
pic: 1018 - Pic 5 - TWINS ? ... (or mirrors ?) Stu Bloom Robot Showcase 7 18-02-2006 15:17
pic: 1018 - Pic 4 - Welded Chassis Stu Bloom Robot Showcase 17 03-02-2006 21:36
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
