Go to Post Success is realizing that anything is possible, persistence is the key. - SlamminSammy [more]
Unread 25-02-2006, 01:57
RedBarons RedBarons is offline
RedBarons is on a distinguished road
Random behavior
I am experience some seriously "out there" behavior. I am essentially trying to get the robot into autonomous mode, drive for XXs, and shoot balls.
When I turn on the robot, nothing happens. If I hit 'reset', then the motors start spinning for XXs, and then stop (which makes me really happy: that's what I want to do ). However, if I reset the robot again, only one of the left or right drive motors may start, sometimes the robot starts shooting balls for no reason, sometimes the motors start spinning but never stop, etc. It's just driving me insane.... It seems completely undeterministic.
If you guys have any idea what's going on, let me know...
1. I use a interrupt based timer to know when to stop driving. The interrupt is handled as follows:
void Timer_1_Int_Handler()
static unsigned int timer1_count = 0; // initialized at compile time
// Make sure we still enforce a 50ms loop
TMR1L = 0xF4;
TMR1H = 0x24;
if (timer1_count < TIMER_1_CNT)
timer1_count++; // Timer1 counter incremented every 50ms
drive_period_expired = false;
else
drive_period_expired = true;
T1CONbits.TMR1ON = 0; // stop timer
PIE1bits.TMR1IE = 0; // disable interrupt
drive_period_expired is an unsigned char global variable that is initialized to false.
The timer is initialized in user_routines.c, in the user_initialization() function.
2. I am essentially trying to jumper out into autonomatic mode right off the bat in main.c:
if (statusflag.NEW_SPI_DATA)
Process_Data_From_Master_uP();
// Kick start autonomous mode
autonomous_mode = 1;
if (autonomous_mode)
User_Autonomous_Code();
3. In user_routines_fast, I initiate the timer (Autonom_Code_Init()) and then call a state machine (Autonom_Code_Handler())
void User_Autonomous_Code(void)
/* Initialize all PWMs and Relays when entering Autonomous mode, or else it
will be stuck with the last values mapped from the joysticks. Remember,
even when Disabled it is reading inputs from the Operator Interface.
pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
/* Initialize autonomous code */
Autonom_Code_Init();
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
Autonom_Code_Handler();
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
Autonom_Mode_Init():
void Autonom_Code_Init()
T1CONbits.TMR1ON = 1; // enable timer
Autonom_Mode_Handler():
Essentially, if drive_period_enabled == FALSE (see step 1), then the pwms for the drive motors are set to 127, else, they are set 254.
void Autonom_Code_Handler()
static unsigned char autonom_state = AUTONOM_STATE_DRIVE;
switch(autonom_state)
case(AUTONOM_STATE_DRIVE):
pwm01 = 254; // left motor
pwm02 = 254; // right motor
// Next state
if (drive_period_expired == true)
autonom_state = AUTONOM_STATE_SHOOT;
break;
case(AUTONOM_STATE_SHOOT):
pwm01 = 127;
pwm02 = 127;
default:
break;
Unread 25-02-2006, 02:02
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Random behavior
Without looking at the code, I wonder if you are running into the high-priority interrupt problem.
Are you using the new library files from IFI's website?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 25-02-2006, 02:03
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: Random behavior
I would be interested if anyone knows an answer to this, because before we shipped my code was exhibiting similarly random behaviors. I have a decision structure that checks the value of an OI button and a limit switch and gives one motor a value if the button is down but the limit swith isn't. I am definitely just assigning different values to the same pwm output, but for some reason it moves two different motors depending on the OI switch. It could just be some deeply-nested logical error, but I would really hope that there's something in the camera or tracking code that's causing this.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 25-02-2006, 02:13
Re: Random behavior
Thanks for your reply. I am using older libraries (10/2005), but the timer relies on low priority interrupt.
Unread 25-02-2006, 02:23
Re: Random behavior
In prior efforts, I had some motors starting spinning while their pwm cmd is not even used anywhere in the code !! That adds a black magic sort of twist to the robot. Beautiful.
Unread 25-02-2006, 02:30
Re: Random behavior
I'll add that, reading an other post on this forum, I added the line:
#pragma interruptlow InterruptHandlerLow save=PROD,section(".tmpdata"),section("MATH_DATA")
We ended up shipping a stripped down version of our control SW, but I'd like to nail down what the problem is.
Unread 25-02-2006, 11:03
Re: Random behavior
The call to Getdata() will change the value of autonomous_mode to reflect the state of the pin on the competition port. Without a dongle connected, the while loop in User_Autonomous_Code() will execute once and exit. Your main loop will end up calling Process_Data_From_Master_uP(), then User_Autonomous_Code(), repeatedly.
Unread 25-02-2006, 14:03
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Random behavior
Remove the statement autonomous_mode = 1;. There are 2 ways to test autonomous code
1.You could test your code using a dongle (build instructions here ).
2. The quick and dirty solution is to your team number to 0000 by setting the dip switches on the OI to 0000 and tethering it to the Robot Controller. Warning: This will ALWAYS run autonomous. Run it on blocks so the robot doesn’t get away from you. Don’t leave the team number at 0000 because some unsuspecting team member may turn it on and the robot will attack them.
TMR1L = 0xF4;
TMR1H = 0x24;
Originally Posted by PIC18F8722 manual pg169
A write to the high byte of Timer1 must also take place
through the TMR1H Buffer register. The Timer1 high
byte is updated with the contents of TMR1H when a
write occurs to TMR1L. This allows a user to write all
16 bits to both the high and low bytes of Timer1 at once.
I don't think this keeps a 50ms timer. TMR1H is a buffer register and only writes to the actual high byte of the register when TMR1L is written. I think you need to write to TMR1H first and TMR1L second.
It would be far easier to just increment a counter in the 26.2 ms area of the Autonomous loop like so:
static int auto_counter=0;
        auto_counter++;
2 counts will give you ~50 ms and it will be synchronized to the rest of your autocode (timer interrupts are not synchronized to the 26.2ms auto loop)
If you still have this problem or any other problems, I will be at the Pittsburgh Regional which is your first regional (I assume you are on Team 63 Red Barons). I should be working at the Robot Inspection table.
Robot Inspector
Unread 25-02-2006, 18:59
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Random behavior
That loop is not guaranteed to be 26.2ms - it can go for many times that length before you trigger a blinking red light. Using the timers is a much more reliable way to get time.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 25-02-2006, 23:03
Re: Random behavior
Thanks. Man does it sound like a stupid mistake...
Wierd search behavior.... Salik Syed Programming 7 23-02-2006 13:12
Bad behavior in the hotels. Tiki General Forum 45 26-03-2005 23:39
Random Page Loader coreyk Chit-Chat 4 16-08-2004 18:58
About people and their random posting archiver 2001 5 24-06-2002 04:21
How random is random???? archiver 1999 0 23-06-2002 21:59
