Go to Post I'm sure you can come up with something, with a bit of warped thought! ... and if not, warped thinking is what your team's Engineers are for! :) - kmcclary [more]
Unread 20-02-2006, 19:06
orelinde's Avatar
orelinde orelinde is offline
Parental Unit
FRC #1733 (Polarbots)
Team Role: Parent
orelinde has a spectacular aura aboutorelinde has a spectacular aura aboutorelinde has a spectacular aura about
Static Cling??
okay we run the robot. and then afterwards we get zapped everytime we touch something around the robot. we did use carpets as conveyor belt. and the wiring has been carefully checked and rechecked. the grounding multiple checks on it. i can walk by and then touch metal and get zapped every time. What can we do to stop this from happening or is this normal?
He walked so quietly i could have shot him in the dark...so I did then laughed my tush off.
And you call me strange like it is a bad thing?
I took a test that says I am a geek, My son took same test he is an extreme geek. I am so proud.
Unread 20-02-2006, 21:16
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Static Cling??
Originally Posted by orelinde
okay we run the robot. and then afterwards we get zapped everytime we touch something around the robot. We did use carpets as conveyor belt. and the wiring has been carefully checked and rechecked. the grounding multiple checks on it. I can walk by and then touch metal and get zapped every time. What can we do to stop this from happening or is this normal?
I'm not sure what you can do to stop it, but as a start, I can tell you why it's happening - just look at a Van DeGraf generator. If you have a belt, you've got good start on one.
I got a good jolt off our robot once too! We have a rubber belt on PVC plastic rollers. Carpet would be even more likely to make static, I would think.
You might try making something to keep the charge at the top and bottom of the belt thee same and drain off the charge.
You might try spraying the belt with a product like "Static Guard" too.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 25-02-2006, 11:07
orelinde's Avatar
Parental Unit
Team Role: Parent
Re: Static Cling??
okay forgive me for sounding not quite with it but well i am not quite with it could you please explain how to "keep the charge at the top and at the bottom and drain off the charge" We have tried to build a safe robot but it seems to me that getting zapped while fun for some *looks at son* i did not enjoy the experience. *chuckles*
Other then the electrical issue i have learned as a parent so much froom this experience. i love seeing the students accidently learning in a fun positive way and wish we have this when i was growing up.
Unread 25-02-2006, 13:00
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Static Cling??
The way I understand it is that you would place metal "brushes" on the top of the belt and the bottom roller (where you would normally tap off charge on a VanDegraff), and short the two together.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 25-02-2006, 16:06
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: Static Cling??
Please see thread
http://www.chiefdelphi.com/forums/sh...&highlight=van
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 26-02-2006, 11:39
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
Re: Static Cling??
just a thought but the carpet conveyor belts are on wood spindles. doesnt wood have no conductivity? i mean if it is running on wood then the carpet shouldnt be giving static to the frame.
Unread 26-02-2006, 14:10
Re: Static Cling??
Static electricity thrives on insulation. No, really. If your belt and spindles were conductive, the electrons would not be accumulating and giving you shocks. It's the physical motion of the material that pulls the electrons along and drops them all off in the same place.
To drain off the charge, you can use the sort of wire-brush thing some aircraft have at the trailing edges of the wing, or you can try putting some pointy metal aiming at the top and bottom rollers, connected to the metal frame of the robot.
Unread 26-02-2006, 14:17
Umm Errr...
Re: Static Cling??
Maybie a stipid idea, but how about Anti-static laundry spray?
They sell it at the dollar store by my house. I use it as potato cannon fuel. It definately works at preventing static on sweaters and whatnot.
1139 Alumni
Unread 26-02-2006, 17:53
Eldarion's Avatar
Re: Static Cling??
If you are using it as potato cannon fuel, it sounds pretty volatile. Wouldn't it evaporate and therefore quit working relatively quickly?
Also, I wonder what would happen if a spark did occur, and a flammable substance was sprayed with that stuff. Big fireball?
-- Thomas Paine
-- Anonymous
Unread 26-02-2006, 18:20
Re: Static Cling??
Originally Posted by mechanicalbrain
I recommend seeing if you can isolate belts from all conductive materials. For example, rubber spacers, plastic screws, and so forth.
That's exactly the wrong thing to do in this case. If you can manage to connect the belts etc. to a conductive frame effectively, the problem will be much reduced.
And absolutely do not try to fix things by connecting anything to your electrical ground. What you'll end up with is high voltages on your wiring, which will very likely damage the electronics each time a static zap occurs.
Unread 26-02-2006, 18:25
Re: Static Cling??
As Alan said, the rollers themselves are fairly small, and any excess electrons will be quite anxious to jump off the the next available particle party boat. You can easily drop the static charge in your roller by connecting them to the frame, and connecting the frame to the ground (if your wheels dont do a good enough job, drop some long zip ties to the floor) This will induce a charge in the frame material and give the static in the rollers a straight path to the ground.
Unread 26-02-2006, 19:44
gondorf's Avatar
Re: Static Cling??
small rollers?!?!
our top spindle has a 15" diameter and is made of solid plywood.
it weighs 20 pounds
you are right though. perhaps another ground bolt will work if we add a drag chain.
just a thought but if your robot gives a static discharge to the inspector do you think he will fail you?
Unread 26-02-2006, 19:45
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Static Cling??
Just make sure you touch the robot first!
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 26-02-2006, 22:29
Umm Errr...
Re: Static Cling??
I think the flammable part is just a solvent or pressurized propellent or both. In any case, that part evaporates while the active ingredient sticks around. There is a label on the bottle that says something to the effect "for risk of fire, do not peel apart clothes while spraying."
Some basic background on static:
"static" does not behave like the electricity you are used to. It occurs when you have an area with a different density of electrons than the areas around it. Think electrical pressure difference." The only way to get rid of this is by direct contact with an area of a lower electron density or through a conductor that connects to an area of lower charge density. The ground can be though of as a vast electron sink. If you can connect the thing you are having problems with to the the ground through a conductor such as some bare wire touching the ground, you might be able to solve your problem. It would equalize the charge density. At the very least, you could connect to a large conductor(such as your frame) , which would spread the charge out over a larger area, decreasing its density.
1139 Alumni
Unread 27-02-2006, 01:41
Eldarion's Avatar
Re: Static Cling??
The only problem I could think of is that the balls themselves are pretty nice charge carriers, such that the robot, even while equalized internally, would develop an overall charge. The same would hold true with the balls.
Then again, maybe this is only if a team is shooting a lot of balls!
-- Thomas Paine
-- Anonymous
Static Variables amateurrobotguy Programming 8 04-03-2005 00:40
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Static Electricity JeffO Championship Event 5 19-04-2004 11:04
Stupid Question about Static Electricity Novice100 Electrical 5 04-02-2004 05:15
Static Electricity archiver 2001 12 24-06-2002 00:34
