Go to Post Does this mean it's too late to ask for a flux capacitor? - Peter Matteson [more]
Unread 25-02-2006, 17:27
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Re: Self-righting
to solve our problem with tipping, #340 has designed a wheelie bar that comes down when needed to keep the robot down while going up the ramp. it weighs all together including the pneumatics 4 pounds.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 25-02-2006, 17:29
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
Re: Self-righting
well that wouldn't work for us but maybe we could use a light weight wheelie bar just have it pulled in slightly or something
Unread 25-02-2006, 17:34
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Self-righting
Unless you're gunning for the ramp, I don't think you seriously need to be worried about tipping. Our robot last year was unable to right itself, and it extended up to 13 feet in the air. We got hit with our robot holding tetras at least 9-10 feet in the air, and the only time we ever tipped was because another robot's arm became entangled with ours and pulled us down.
Without high extensions or wedged robots this year, tipping is one of my least worries. Those teams that took advantage of the bumpers will be in even better shape with an extra 10-15 lbs. on the bottom of their robot.
Our team hasn't experienced any problems with getting poof balls caught underneath us, but that will be an individual issue depending on what your robot's ground clearance is. Poof balls under a robot "bouncing it" onto its side would be the only way I see teams getting tipped UNLESS they go for the ramp.
Unread 25-02-2006, 19:00
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
Re: Self-righting
Originally Posted by Beth Sweet
As one of the technical mentors showed me (as I was screaming at him), it would take a pretty good fall for us not to be able to get back up. I think that they have so much weight in the front that it just pops back up again.
Quick explanation for beth's comment, as i was the one ignoring her screams:
i was able to tip our robot so that the highest most point was about 1ft from the ground
as we stand now our robot is only 68 pounds (we will be adding more) but of those 68 pounds, 65 of them are within 9 inches of the ground because the rest is just a hopper. we also plan on adding an extra 50 to the chasis at the competition, as well as battery and bumpers. So in the end, we should have about 140/145 pounds within 1ft from the ground spread out through the entire chasis
needless to say, with such a low CoG, we shouldnt have any tipping issues with our bot
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
Unread 25-02-2006, 19:11
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
Re: Self-righting
Our robot had a small problem of tipping coming off the ramp due to a higher-than-wished CG. We solved the problem by writing a ramp unmount procedure and by adding several pounds to the front (we were underweight by like 9 pounds.)
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 25-02-2006, 20:18
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Re: Self-righting
We currently don't have anything to prevent tipping on this years bot but we may add something at our first regional if we find out we need it.
On last year's bot we had what we called Wheelie Stilts, very simple and light weight, and no powered parts. All you need is some Aluminum Angle, String, and two bolts in the size of you choice.
Our the bottom half of our robot last year was basically a box (as many bots are this year)
What we did was:
1. Cut a piece of Aluminum Angle (to size you need), and cut about 1" of one of the legs (right or left side depending on the side you are working on) off (so you have for example 19" of true 90 degree angle and 1" of flat stock.)
2. Line up the angle so it sits around the existing frame and the 1" flat spot is up and on the side of your robot the spot you choose should be strong enough to support the weight of your robot and drill a hole in the side of your frame and another on the flat part of the Al angle.
3. Put a bolt through both holes (line the with a washer in between them put a nut on and tighten it (leave it lose enough so the angle can pivot).
4. Test lean your robot back (simulate a flip) and the angle should swing out. Now find how far it must swing our to stop the robot from falling and right itself again.
5. Measure and cut a piece of string to stop it at that point and drill two more holes to tie the string to. Tie the string off and test lean it again to make sure. Adjust as necessary.
It does work last year at West Michigan we had our arm out and up trying to cap a corner goal, someone pushed us from behind and we fell forward against the goal. After they backed off we swung back up so fast we tipped backward and the Wheelie Stilts stopped us from falling over backward.
Pic This picture isn't very good but its the best view of the stilts that we uploaded last year. The pivot point is right in the middle of the 8 you can see the string on the other side.
Hope this helps
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 25-02-2006, 23:12
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Re: Self-righting
I saw one of the scrimmage videos. In it, one team has these plates the folded agianst the robot ball container, but would open up so the balls would be able to bounce in(i'm assuming), anyway if they wer etipped over, it seems like they would be able to right themselves.
VEX Robotics Blog
Unread 26-02-2006, 01:39
Re: Self-righting
self righting technology? thats old stuff!
Unread 26-02-2006, 01:57
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: Self-righting
We were joking around one day about how we could just tip ourselves onto the ramp if we wanted the points at the end of the match, since we were so top heavy. Now that i think about it it wouldn't have been a bad idea, easier than raising our chassis to go up the stupid thing.
Unread 26-02-2006, 21:09
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
Re: Self-righting
probably a very stupid idea but if you put a pneumatic cylinder on each side if the robot tipped over you could use the pneumatic to self right the bot.
i just thought of this because I remember the self righting robots on robot wars and they used pneumatics to right themselves
Unread 28-02-2006, 18:24
pyro20911d
Posts: n/a
Re: Self-righting
I think everyone gets it
no one
can save
themselves
Unread 28-02-2006, 21:52
spamified88's Avatar
spamified88 spamified88 is offline
AKA: Sean
FRC #1257 (Parallel Universe)
spamified88 will become famous soon enoughspamified88 will become famous soon enough
Send a message via AIM to spamified88
Re: Self-righting
Originally Posted by Tim566
can anyone think of a way to reduce the risk of tipping without redesigning the robot or adding much weight? ( our robot is at the weight limit assuming our scale is accurate but I am hoping the scale added weight to the robot that way we have room to make little add-ons come practice day)
Easy! Drive slower, and switch the jumpers on the victors powering your drive motors to coast! The coast setting really does work, because when our driver decides to stop short ( which he usually does), the robot slows down instead of coming to a jolting stop and then flip over. Though I don't think the coast setting works in reverse!
Head rule guru, I know everything, or at least I'm supposed to...hehe
PARALLEL
UNIVERSE
Unread 01-03-2006, 14:27
rjp744's Avatar
rjp744 rjp744 is offline
Bob Perry
FRC #0744 (Shark Attack)
rjp744 is an unknown quantity at this point
Re: Self-righting
believe me its been blazing through my mind for weeks now I was just wondering if any team took measures to correct the tipped cow situation... because quite a few of robots seem to be built taller with more top weight making them more susceptible to being tipped over
There are pros and cons to being tall. Although you are top heavy, if your shooter is up on top(60 inches) you cannot be blocked. It all depends on the strategy.
Unread 01-03-2006, 14:29
rjp744's Avatar
Bob Perry
Re: Self-righting
You can also try acceleration and deceleration functions in the coding. That works for both directions if done right.
Unread 01-03-2006, 15:00
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
Re: Self-righting
You have officially jinxed us all
Righting a robot... archiver 2001 2 24-06-2002 00:26
