Go to Post Can you believe we have 8 FRC teams in Arkansas this year??? Not quite Michigan, but... - Meredith Novak [more]
Unread 26-02-2006, 06:43
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: IFI loading problems
I would try uninstalling and then reinstalling.
Unread 26-02-2006, 12:00
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
I have tried that at least 10 times. I have even deleted all files out of windows explorer.
Unread 26-02-2006, 12:10
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
out of curiosity how old is the laptop and what operating system is it using there may be a problem with the OS that it cannot validate the Serial port unless there is something plugged into USB, before the regional i would recomend updating all of your hardware drivers on the laptop itself
KK4KQO
http://voltair.us
Unread 26-02-2006, 12:15
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
You might try a different flash disk, to determine if it is specifically that device that it requires...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 26-02-2006, 13:31
FRC #0935
I'll try that on monday. Thanks for your help.
Unread 26-02-2006, 22:05
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
I would hazard a guess that wherever the registry thinks the default code is hapens to have been on the thumbdrive, and once it got on there it started messing up and it hasn't rewritten it with something from the harddrive. Installers are notorious for not deleting things like this when they are run through their uninstall. The problem with IFI loader is that if it can't find the file it wants to download, the download button disappears, and my programmers have reported mixed results with choosing the proper file once it starts doing that. The solution would appear to be choosing a program on the harddrive from browse (not the drop-down menu), restarting the program after you choose a valid hex file, and/or doing a registry search for one of your hex files (to figure out where IFI loader stores the "most recent hex files") and deleting any that don't point to the local C: drive.
Hope this helps,
~Kyle
Unread 26-02-2006, 22:16
FRC #0935
Do you mean delete registry entries or delete files from windows explorer.
Unread 26-02-2006, 23:31
Eko's Avatar
Eko Eko is offline
Registry entries
Unread 28-02-2006, 16:36
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Are you downloading via real serial port or usb-to-serial converter? If usb-to-serial converter check that the com port number didn't change when the flash drive isn't plugged in.
Unread 28-02-2006, 19:10
FRC #0935
I am using a serial port.
Unread 05-03-2006, 18:16
sur2124 sur2124 is offline
FRC #0116
sur2124 is an unknown quantity at this point
I agree, if that dosn't work resave the program so it's on your C drive.
IFI Loader problems Hieb Programming 3 18-01-2005 13:45
IFI Loader problems billstu Programming 22 23-03-2004 11:39
IFI Loader Problems lasindi Programming 6 05-02-2004 06:06
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
