Go to Post No one shall stand between me and my sleep. - Adam Y. [more]
Unread 26-02-2006, 08:16
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
using extrude to cut away material, but its backwards
i am having a problem with using the extrude function to cut away some material. i know to choose the extrude option, then to change it to cut mode, and then i select the part of the sketch that i want cut away, but it removes everything that is not selected. its been a while since i used inventor but i dont remember that ever happening. btw im using inventor 10.
i have included some screen shots of what is going on.
ID:	4032  Click image for larger version
ID:	4033  Click image for larger version
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 26-02-2006, 09:43
Fireworks 234's Avatar
Fireworks 234 Fireworks 234 is offline
Purdue FIRST Programs Enthusiast
AKA: Joe Tonte
FRC #3180 (Blaise of Glory)
Fireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of light
Re: using extrude to cut away material, but its backwards
I see what the problem is, you chose the bottom cut feature; that one leaves everything around what you chose. You need to choose the one above it but below extrude, that one should work.
Blaise of Glory - 3180
Previous History:
Member - Cyber Blue (234) 2004-2007
Mentor - Harrison Boiler Robotics (1747) 2008-2010
Mentor - Blaise of Glory (3180) 2011-?
Eagle Scout as of 10/19/2006
Unread 26-02-2006, 14:09
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
oops, i geuss i didnt see that.
Unread 10-03-2006, 23:26
Ebolagirl's Avatar
Ebolagirl Ebolagirl is offline
I <3 Inventor!!!
AKA: Tracey
FRC #0418 (Purple Haze/LASA Robotics)
Ebolagirl has a spectacular aura aboutEbolagirl has a spectacular aura aboutEbolagirl has a spectacular aura about
Send a message via AIM to Ebolagirl
Is there any particular reason you aren't using the cut feature under sheet metal features? Afterall, that's what it's there for, so I think it works better than the extrude backwards thing. Just a thought.
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot."
-Someone
My other passion... http://www.cdc.gov/ncidod/dvrd/spb/m...s/ebola/qa.htm
Isn't it adorable?
http://www.giantmicrobes.com/calamities/ebola.html
Unread 10-03-2006, 23:37
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Cut is there to see cuts on sheet metal flat patterns. Either that's one thick piece of sheet metal or extrude is the correct feature to use.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 11-03-2006, 00:25
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
You can use cut the same way that you use extrusion, except it cuts. You simply create your sketch, select it, and specify how deep you want it to cut, and press 'ok'. Perhaps you should investigate the features a little more. It's good to know different ways of accomplishing the same task. Using cut as opposed to extrusion just allows you to keep your features a little more organized (cut coincides with cutting and extrusion coincides with extending).
-Someone
Isn't it adorable?
Unread 11-03-2006, 01:40
No. There is no Cut feature in the part feature list for a standard part. Extrude only (well, there is also Shell, which can be a little tricky to use).
Unread 11-03-2006, 03:13
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
I never said it was under the 'part features' section. I said it was under the 'sheet metal features' section.
Although, I think I now realize where the confusion is coming from. The original poster, CmptrGk, did not specifiy whether he was working in a new Sheet Metal.ipt or a new Standard.ipt. And since I always work in a sheet metal (because that's what I was taught), and from what it sounds like, you work in a standard, we are talking about two different things. In a sheet metal, under the 'sheet metal features' section, there is a cut tool. It is a little yellow square with the center cut out (if I had Inventor in front of me I would post an image). That tool allows you to cut out sketches similar to a backwards extrusion.
-Someone
Isn't it adorable?
Unread 11-03-2006, 06:46
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
While it is true that there are many ways to generate most features, best practices for a NON sheet metal part would be to use the extrude/subtract option as was originally shown (attempted) by "CmptrGk"
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 11-03-2006, 14:48
Ebolagirl's Avatar
I <3 Inventor!!!
AKA: Tracey
ok, I'll agree with that one.
-Someone
Isn't it adorable?
Unread 20-03-2006, 20:24
Andy A. Andy A. is offline
Getting old
FRC #0095
EbolaGirl is close. I would have used an extruded cut, but there is another way thats not bad.
There is a similar command to Cut for a standard part. It is call 'Split'.
It can be used in the same way as Extrude/Cut, but it is rarely from what I've seen. I suppose it is a legitimate use, but I don't see any reason to over it unless someone asks you to. Split is supposed to be used to break a solid body into two separate pieces. Although, given how well Inventor handles separate solid bodies in a single part file, I don't know why you would want to do that. Solidworks is way ahead here.
It's one of those commands no one seems to use. I'm sure someone asked for it and it gets plenty of use by them, but I can't think of any good reason why.
I can post pictures and a quick howto if someone wants it. Otherwise, check the help file.
Unread 08-04-2006, 13:26
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
I myself would have shot for the shell command in a standard.ipt. Just a remove face and a thickness means that you dont have to measure out the rectangle on the surface, and if left with a whole to deep in the bottom, it could have just been a move face upwards.
A sheetmetal as previously mentioned would have to have been extremely obease to look like that. However, my knowledge with sheetmetal.ipt files is limited, and i am actually going to go flirt with it right now because it sounds more useful than i previously inferred.
Material help White_Orpheus 3D Animation and Competition 10 21-11-2005 10:58
Backwards Mounted Motors Mike Programming 11 22-06-2005 16:21
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
