| View Poll Results: how many balls will teams get in in auto | |||
| 10 for 10 |
11 | 18.33% |
| 9 for 10 |
6 | 10.00% |
| 8 for 10 |
3 | 5.00% |
| 7 for 10 |
10 | 16.67% |
| make a few abuot 3-6 of them in |
27 | 45.00% |
| balls in auto hehe we love the defence |
3 | 5.00% |
| Voters: 60. You may not vote on this poll | |||
Re: 10 ball auto mode
You are not safe anywhere on the field.
See ya at UTC. |
I think that while few teams will be able to score in autonomous mode, those that are able to will be able to score a high percentage of their balls. |
If a robot cannot get all 10 of its balls into the center goal within the first 4 seconds (remember, you have to lock on and give your shooter time to get up to speed in that 4 seconds), then there is no gurantee they will get all 10 in. Your average robot will be able to drive from their starting position to their opponent's in 4 seconds, meaning any robot that takes longer than this is susceptable to defense.
Not moving does not ensure you safe from defense either. Although you will be able to start firing sooner since you don't have to move, and you will be further from your opponents than you might otherwise be, you are now in a known location (it's much easier for opponents to simply charge towards your starting position than to drive out in the middle of the field and hope they hit you as you're moving). They can still hit you where you're sitting too; it takes one good hit to turn your robot and make you miss a few of your shots. I think a good number of robots will be able to shoot into the center goal in auton, but the numbers made will be more like 3-7 in. Those that consistently shoot in 9 or 10 will find those numbers change very quickly when they come under fire from autonomous modes that are simply "drive forward for 10 seconds". |
But you never know. Defense could decide Nationals. Because until the first competition, nobody really knows how there robot will run with other drivers beating and banging out on the field. |
Our bot will be capable of getting 5-10 balls probably every autonomous, but we added sonar to be effective on attacks because we know there's always going to be somebody out there better than us at shooting, hence they can have the prized 1st or 2nd starting position. Also I believe taking out the opponents best shooter is a critical strategy if they can consistently shoot more than you. Although in our case its not worth it to take out a 4 ball shooter when we know we can get a minimum of 5. So it depends. Also I'm sure for most designs, the closer you get, the more consistent your shots will be. So the teams that shoot from the start spot, not only deal with trajectory/distance issues, they also are sure to get nailed pretty consistently. |
I seriously don't know how many teams will take advantage of how easy it is to create a simple defensive autonomous though; 2 years ago you could employ an effective defense by running forward to prevent your opponent from knocking down the ball, yet I do not remember seeing any other teams at Nats do this other than us (of course that was just our division, and some of the matches). Quick warnings on this though; you do run the risk of damaging your robot by doing the "suicidal charge" (one match 2 years ago had us run a caster full speed into the platform, bending it at a 45 degree angle and severely compromising driving ability). Also, you may have to limit how fast you drive your robot if the refs start flagging teams for high speed ramming in autonomous. Quote:
1. A bunch of robots flying across the field to hit their opponents, with autonomous being decided by 1 or 2 balls. 2. Both teams ignoring defense and having a high scoring shoot out. Quote:
#7
Let me throw my $0.02 into kitty.
Refer to this rule: <G22> Intentional ROBOT - ROBOT Interaction - Strategies aimed solely at the destruction, damage, tipping over, or entanglement of ROBOTs are not in the spirit of the FIRST Robotics Competition and are not allowed. I would be very careful about making an autonomous mad dash across the field with the sole purpose of stopping another robot from shooting. If you can get in front of them and stop their shots than I see no problem. But if you miscalculate and damage another bot you may be penalized. FIRST also mentions long distance, high speed ramming. IMHO I would consider 15 feet long distance. Also, if another team has a robust bot and can take a hard hit, they may change their autonomous to have your bot hit them in the hopes of you getting the penalty. |
#8
shaun |
| Sending variables to Auto Mode | Adrien | Programming | 4 | 19-02-2006 21:51 |
| Auto aim in user control mode | JamesBrown | Programming | 2 | 19-02-2006 12:58 |
| auto mode | nuggetsyl | General Forum | 12 | 13-02-2006 19:45 |
| camera auto mode pwm contention? | AL_E | Programming | 4 | 24-01-2006 22:10 |
| Did you use Auto Servo Mode? | Greg Marra | Programming | 8 | 27-04-2005 15:35 |
