Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
View Poll Results: how many balls will teams get in in auto
10 for 10 11 18.33%
9 for 10 6 10.00%
8 for 10 3 5.00%
7 for 10 10 16.67%
make a few abuot 3-6 of them in 27 45.00%
balls in auto hehe we love the defence 3 5.00%
Voters: 60. You may not vote on this poll
Unread 26-02-2006, 15:23
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: 10 ball auto mode
If a robot cannot get all 10 of its balls into the center goal within the first 4 seconds (remember, you have to lock on and give your shooter time to get up to speed in that 4 seconds), then there is no gurantee they will get all 10 in. Your average robot will be able to drive from their starting position to their opponent's in 4 seconds, meaning any robot that takes longer than this is susceptable to defense.
Not moving does not ensure you safe from defense either. Although you will be able to start firing sooner since you don't have to move, and you will be further from your opponents than you might otherwise be, you are now in a known location (it's much easier for opponents to simply charge towards your starting position than to drive out in the middle of the field and hope they hit you as you're moving). They can still hit you where you're sitting too; it takes one good hit to turn your robot and make you miss a few of your shots.
I think a good number of robots will be able to shoot into the center goal in auton, but the numbers made will be more like 3-7 in. Those that consistently shoot in 9 or 10 will find those numbers change very quickly when they come under fire from autonomous modes that are simply "drive forward for 10 seconds".
Unread 26-02-2006, 16:51
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
All of this is true. But no one knows whats going to happen at the competitions. I don't think running into the other team will happen a lot until the finals. Its just not a viable strategy in my mind. If you can't shoot the 3 point goal, and you need to start in one of the back positions so other people can shoot 3 pointers, then defense is probably a good strategy.
But you never know. Defense could decide Nationals. Because until the first competition, nobody really knows how there robot will run with other drivers beating and banging out on the field.
Unread 26-02-2006, 17:41
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I think thats a good assessment, and hopefully most teams are taking that autonomous routine seriously. It's very simple, but it's going to be very effective. Unfortunately you're going to miss and nail the wall sometimes, and regardless I think its important to have 1 teammate almost every match that can run an autonomous interference pattern. Scouting will eventually tell you where a team will wind up while they shoot, be it in the start spot or somewhere else. Then you can just point and shoot.
Our bot will be capable of getting 5-10 balls probably every autonomous, but we added sonar to be effective on attacks because we know there's always going to be somebody out there better than us at shooting, hence they can have the prized 1st or 2nd starting position. Also I believe taking out the opponents best shooter is a critical strategy if they can consistently shoot more than you. Although in our case its not worth it to take out a 4 ball shooter when we know we can get a minimum of 5. So it depends.
Also I'm sure for most designs, the closer you get, the more consistent your shots will be. So the teams that shoot from the start spot, not only deal with trajectory/distance issues, they also are sure to get nailed pretty consistently.
www.179swampthing.org
Unread 26-02-2006, 22:26
The Arizona Mentor
AKA: Andrew
Exactly, and in reality any team can do this autonomous mode. Have a partner without an auton? Simply have them enter their drive pwms as full forward/reverse in their autonomous routine, line it up on field, and poof! You have one defensive autonomous mode, even if not consistently effective.
I seriously don't know how many teams will take advantage of how easy it is to create a simple defensive autonomous though; 2 years ago you could employ an effective defense by running forward to prevent your opponent from knocking down the ball, yet I do not remember seeing any other teams at Nats do this other than us (of course that was just our division, and some of the matches).
Quick warnings on this though; you do run the risk of damaging your robot by doing the "suicidal charge" (one match 2 years ago had us run a caster full speed into the platform, bending it at a 45 degree angle and severely compromising driving ability). Also, you may have to limit how fast you drive your robot if the refs start flagging teams for high speed ramming in autonomous.
Once regionals get more than halfway through the qualifying rounds, most matches autonomous modes will become...
1. A bunch of robots flying across the field to hit their opponents, with autonomous being decided by 1 or 2 balls.
2. Both teams ignoring defense and having a high scoring shoot out.
True true. We will see starting next week.
Unread 26-02-2006, 23:55
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Let me throw my $0.02 into kitty.
Refer to this rule:
<G22> Intentional ROBOT - ROBOT Interaction - Strategies aimed solely at the destruction, damage, tipping over, or entanglement of ROBOTs are not in the spirit of the FIRST Robotics Competition and are not allowed.
I would be very careful about making an autonomous mad dash across the field with the sole purpose of stopping another robot from shooting. If you can get in front of them and stop their shots than I see no problem. But if you miscalculate and damage another bot you may be penalized.
FIRST also mentions long distance, high speed ramming. IMHO I would consider 15 feet long distance.
Also, if another team has a robust bot and can take a hard hit, they may change their autonomous to have your bot hit them in the hopes of you getting the penalty.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 27-02-2006, 06:24
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Refer to this rule:
First off i do not think 15 feet from a dead stop is going to be called unless your robot is going really fast. Get used to that because i perdict that 60-70% of robots will do that. All caster bot good luck.
shaun
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
[IMG] code is Off
Sending variables to Auto Mode Adrien Programming 4 19-02-2006 21:51
Auto aim in user control mode JamesBrown Programming 2 19-02-2006 12:58
auto mode nuggetsyl General Forum 12 13-02-2006 19:45
camera auto mode pwm contention? AL_E Programming 4 24-01-2006 22:10
Did you use Auto Servo Mode? Greg Marra Programming 8 27-04-2005 15:35
