Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
  #31   Spotlight this post!
Unread 26-02-2006, 13:29
orelinde's Avatar
orelinde orelinde is offline
Parental Unit
FRC #1733 (Polarbots)
Team Role: Parent
orelinde has a spectacular aura aboutorelinde has a spectacular aura aboutorelinde has a spectacular aura about
Re: final weight
10 pounds over the limit there abouts. but we have already worked out a plan for getting under the limit. slimfast
He walked so quietly i could have shot him in the dark...so I did then laughed my tush off.
And you call me strange like it is a bad thing?
I took a test that says I am a geek, My son took same test he is an extreme geek. I am so proud.
  #32   Spotlight this post!
Unread 26-02-2006, 13:34
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
Re: final weight
hmm...I dunno if slimfast is well...fast enough you may need to use liposuction instead...just a thought... hey i wonder what if when they weighed it we put attached lots of helium balloons? it could work right?
The only thing about the future of which we can be
certain is that it is uncertain and it will be there whether we are or not.
So my advice is to enjoy life in the present while not disregarding the future.
To everyone going to the competions good luck out there and remember whatever you do have fun doing it
  #33   Spotlight this post!
Unread 26-02-2006, 13:38
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: final weight
4 days prior to shipping we were 35 lbs. overweight! Needless to say hole drilling wasn't enough to get us down to the limit. First 5 weeks to build the robot. 4 days to redesign and build the robot again. After getting rid of all the 1/4" plate steel, our hopper, and replacing plate aluminum on our conveyor with canvas we weighed in around 105 lbs. The problem? We can pick up balls, we can shoot balls, we just don't have any place to PUT balls! AND our shooter is unshielded! So thursday at comp. we will be adding in the necessary redesigns.
  #34   Spotlight this post!
Unread 26-02-2006, 13:45
blaskay16's Avatar
Happy Birthday! blaskay16 blaskay16 is offline
President/Driver
AKA: Jeremy
FRC #0815 (Advanced Power)
blaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these partsblaskay16 is infamous around these parts
Send a message via AIM to blaskay16 Send a message via Yahoo to blaskay16
Re: final weight
815 weighted in at 108 so our field weight will be aboutr 130 to 135
  #35   Spotlight this post!
Unread 26-02-2006, 14:03
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: final weight
118 - 119 lbs and proud of it!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
  #36   Spotlight this post!
Unread 26-02-2006, 14:04
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
Re: final weight
200 pounds............ok so i lied it was actually like 118 right before we shipped
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
  #37   Spotlight this post!
Unread 26-02-2006, 14:06
Eisner664 Eisner664 is offline
FRC #1100
Eisner664 can only hope to improve
Re: final weight
Team 1100 is like 118
Not to bad two years ago, we were like .1 under weight!!!!!
Team 1100 Going all the way!!!!!!!!!
  #38   Spotlight this post!
Unread 26-02-2006, 15:01
team1611's Avatar
team1611 team1611 is offline
Team Captain
AKA: andrew
FRC #1611 (Mustangs)
Team Role: Driver
team1611 is an unknown quantity at this point
Re: final weight
Originally Posted by Tim566
wow thats alot...you know theres only so many holes you can drill befrore you compromise structural integrity so you guys should be carefull not to make the same mistake one of the members on my team did taking from a crucial part setting us back. Well good luck to you and all the other teams competing out there.
After cutting as many holes as we could without losing strength, we only lost about 7 pounds. Thats when we decided to take off the lexan around our hopper. The day we shipped our robot, we replaced the lexan with some ... chicken wire (yeah, we're from the south). Actually the chicken wire ended up working better.
Team 1611
  • 2005 Peachtree Regional- Highest Seeded Rookie Award (5th place after qualifying, 4th place overall)
  • 2005 Peachtree Regional- Semifinalists (along with teams 1345 and 1553)
ECDU - East Coast Drivers Union
Team 1611's website
  #39   Spotlight this post!
Unread 26-02-2006, 17:42
Nita's Avatar
Nita Nita is offline
^_^
FRC #1190 (Anonobots)
Nita is just really niceNita is just really niceNita is just really niceNita is just really niceNita is just really nice
Re: final weight
Few days before shipping: 115.4 lbs
Some stuff have been added after that, so I don't know for sure how much it weighs now.
  #40   Spotlight this post!
Unread 26-02-2006, 20:55
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
Re: final weight
hey, that works!!!
I wasn't there when they shipped but, considering our bot is so beautiful and made of like, the lightest stuff we could find, I think it is underweight.... last time I checked, beofre shipping like, the Saturday, that one right before I believe we were like, 75-100.... I hope we stayed that! ::hope hope hope::
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
FIRST Final Jeopardy 2.0! (4/30) EddieMcD Games/Trivia 0 30-04-2005 22:10
Ohio Final Round Pairings Tyler 178 Regional Competitions 19 13-03-2003 22:00
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
