Go to Post If everyone spent half as much time reading and understanding the rules as they do complaining, arguing, and disagreeing about rules, we might not even be having this discussion. - AmyPrib [more]
Unread 26-02-2006, 18:26
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
Wide aspect vs Narrow aspect
After looking at all the pictures in the picture gallery, I noticed that most of the robots, or at least more than I had expected, are narrow aspect(the front is the shorter than the side of the robot, I don't know if other teams use this terminology). Our robot is wide aspect and can pick up balls along almost the entire front. Also, it can turn more easily than any of our narrow aspect robots; which seems like a big deal for trying to collect balls off the floor. So, why narrow aspect? Are there some benefits that I am over looking?
Unread 26-02-2006, 18:30
Re: Wide aspect vs Narrow aspect
I was thinking about the same thing today. I guess the answer is people don't even think of building a wide aspect robot, or are fine with the setup they have been using for years.
Having a narrow robot will make it easier to keep the COG of the robot over its supporting structure as it climbs the ramp, therefore reducing the risk of tipping.
Corey Balint Corey Balint is offline
Now comes without cockiness.
AKA: Corn Dog
FRC #0125
Corey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond reputeCorey Balint has a reputation beyond repute
Send a message via AIM to Corey Balint
The major problem is that if you have a higher center of gravity while going with this wide aspect, you are more probable to fall over while going up the ramp.
Don't be scared to post something that is more than "dave is great" "here's my caption contest entry" and "overdrive is the best thing ever". Say something interesting. Say something that will make others think. Create discussion.
If you do say something that isn't just for fun or praising something, which hopefully you do, just be prepared to back up what you said.
Remember: GP is Gracious Professionalism, not Glorifiying Plesantries. Saying something negative does not mean you are evil. It could help someone out a lot.
Anything that I post is an opinion from my own mind. Some may agree with it, others may not. However do not negatively associate anyone else, including any team I work with, with my opinion.
Unread 26-02-2006, 18:31
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
I'm not sure anyone on our team thought of using the wide side as the front...hm...I'll have to remember that for next year...I guess the benefits depend on what kind of bot you make, just like with anything else.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 26-02-2006, 18:33
If you go up the ramp "sideways" you are more likely to tip. Sideways robots are more likely to drive out from under their game systems, if they are tall (we almost did this at Bellevue, and we are aligned along the long axis). You give up fore-and-aft stability in favor of your wider ball collector. It's not a bad choice, but I'm guessing -- based on last year -- that nine out of ten bots are aligned the other way.
Unread 26-02-2006, 20:07
in between teams
AKA: Luke Van Oort
Although a narrow robot loses a bit of turning capability, it can gain it back thorugh proper design. The reason we went narrow this year is because of our scoring device and ball pickup device. If we were wide, we wouldn't have any room for ball storage. That said, our most successful robot ever (OCCAM 3: The Beast, 2003) was very close to 50:50. It also is the easiest to drive, since it doesn't make snap turns like this year's 6WD and it does turn unlike last year's long 4WD.
Team 1219: 2009 - Mentor
Unread 26-02-2006, 20:40
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
We found it pretty difficult to fit an entire ball harvesting system, ball storing system, ball feeding system, and ball shooting system into the 38" of the robot's length as was. I think turning the bot sideways would even further reduce the amount of space we would have had for all of these different systems.
While a robot like 195's may have benefitted from having a wider area to pick balls up, I think our bot was better built in the "traditional" orientation.
Unread 26-02-2006, 20:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We have a wide robot this year. We chose this configuration for driveability and maneuverability. While 6wd is better than 4wd for long robots, it isn't the be all end all of drive systems. We had 6wd with a long robot last year and it still didn't drive as nicely as a wide robot. Also, the rocking can be annoying.
This year, stability is not too bad because our wheelbase is still fairly long since we are using wheels that are just under 3.5" diameter. We still went with 6wd this year to get up the ramp and still have low ground clearance and small wheels, however, all of our wheels lie in the same plane; the center ones are not lower. It is the best driving robot we've ever had. Our CG is still low enough where it goes up the ramp just fine.
Anyway, my personal opinion is that wide robots drive the best. You can turn without loading up your motors too much.
Unread 26-02-2006, 22:18
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
We thought about both aspects, but chose narrow over wide becuase of the ramp. However, we had to compromise smooth turning with 4 wheel drive.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 26-02-2006, 22:26
Tim566's Avatar
Tim566 Tim566 is offline
FRC #0566 (Hot Wired)
Tim566 will become famous soon enough
"narrow aspect" allows for more depth in the collector system.
The only thing about the future of which we can be
certain is that it is uncertain and it will be there whether we are or not.
So my advice is to enjoy life in the present while not disregarding the future.
To everyone going to the competions good luck out there and remember whatever you do have fun doing it
Unread 26-02-2006, 22:41
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Our robot is the narrow aspect. We considered a wide aspect robot, but we thought getting up the ramp would cause us to tip. We still have a relatively wide collector at 20" and our drive train should be good enough at turning. We shall see when the competition arrives if we made the correct decision.
Team Website
Teamwork Aspect Cyberguy34000 Rules/Strategy 9 14-01-2005 08:14
