Go to Post This web site is a service by our team to the FIRST Community to foster interest and growth in Engineering, the FIRST Competition and Education of youth for the careers of tomorrow. - Mike Martus [more]
Unread 26-02-2006, 21:59
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
Re: Finding servo location?
Other than having a rotary potentiometer or something on it...
Nope =)
Unread 26-02-2006, 22:20
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Originally Posted by rodgadashruba
well i tried that in user routines, in the default code funtion. the code compiles just fine but when i add int he comman
int testTest = PAN_SERVO ;
or
static int testTest = PAN_SERVO;
i get syntax errors
is there a way to access these varible outside of tracking.c?
Yes. Since PAN_SERVO is in a #define statement in tracking.h you just need to make sure you include that .h file. Or just directly use pwm01 if that is what your #define is set to.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 26-02-2006, 22:30
FRC #0957 (WATSON)
Originally Posted by Matt Krass
Keep in mind this tells you where the servo is being commanded to go, not where it is, in most case they're synonomous, but if you're caught on something, or doing a lot of tracking this value could introduce lag which creates oscillations, making it worse, feedback loops, a constantly increasing error, all kinds of bad stuff. Just remember thats where it's trying to be and 98% of the time it should be there.
Please note that the only thing Matt is pointing out are possible error conditions which should not be encountered in normal operation.
1) Do not command your servo to go into a position where the servo's movement is physically limited.
2) Setting the pwm value is where the servo will end up. This is pretty accurate. If you are worried about the speed in which the servo gets to the commanded position versus the speed of your processing loop then use the Hitec specification for the speed of your servo to figure out if you need a delay.
Finding the *final* Servo Center values? Andrew Blair Programming 2 22-01-2006 18:02
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo command confusion?!?!?!?! [527]phil Programming 9 15-07-2005 20:10
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
