Go to Post Do one thing, and do that one thing very well. - Arille [more]
Unread 27-02-2006, 10:36
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Extra Maxi Block
Are you allowed to use more than one maxi block (gold fuse box)? My team is running 7 Victors and only four can be hooked up to the maxi block. If you can use a second one, where can I purchase the second one?
Unread 27-02-2006, 11:46
Re: Extra Maxi Block
Yes, you can use more than one. From the FIRST Q&A:
"The Maxi Fuse Block (part number JEF-531D) is available from several sources, including Terminal Supply Company (http://www.terminalsupplyco.com/ or 800 989-9632)."
Unread 28-02-2006, 22:14
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
The 2006 wiring diagram also shows you can use a secondary maxi block.
Eat, Sleep, Build Robots
Maxi Block Wiring Technique Al Skierkiewicz Electrical 0 06-02-2006 08:40
Warning! Check the screws on your Maxi fuse block! Roland Electrical 1 16-03-2004 21:59
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
