Go to Post Omni wheels are cool... but mecanum wheels are COOL!! - dtengineering [more]
Unread 27-02-2006, 16:43
Billfred's Avatar
Billfred Billfred is offline
Kitbot chassis in Pro/E
Alright, I know I'm in the minority here, but I use Pro/ENGINEER. (The engineering school here at USC uses it and teaches with it, and I'm in no position to load Inventor.)
Today I tried to load up the STEP version of the Kitbot drawings, and the part was nice and visible. Only problem was that while the holes were visible to the eye, they weren't visible to the part file--Pro/E treated the part (the rail, in my case) like it dropped from the sky that way.
Is there a way to get the holes to show up as holes? Is this some case of "It's not a bug, it's a feature!" that I'll have to live with? Can someone design a drivetrain without them?
Unread 27-02-2006, 22:19
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Re: Kitbot chassis in Pro/E
I just started to use pro-e as well.... i figured out the best way to import a file is an in .igs file saved under the nerbs feature when you go to save it in inventor. At first i hated pro-e but now i am coming to terms with it.
Drive-train / chassis weight Andrew Schuetze Technical Discussion 19 07-02-2006 16:51
Tips for KitBot generalbrando Kit & Additional Hardware 15 15-01-2006 21:15
Input On Steel chassis w/wood inset Henry_Mareck Technical Discussion 36 20-12-2005 14:52
Why is the kitbot chassis bowing in horribly Adam Y. Technical Discussion 22 28-01-2005 22:53
KOP Chassis & Transmission Support/Documentation JVN Technical Discussion 0 10-01-2005 00:28
