Go to Post I have never seen a coach with a better ability to yell with love. - IndySam [more]
Unread 23-02-2006, 23:40
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
Re: Does CAD get respect on your team?
Originally Posted by Henry Anthony
I am wondering if your team considers CAD as an important part of the competition or is there little interest in it?
CAD is theonly way to go for 663. Without CAD, your machinist might get mad if you need to add a hole here or there. It is much easier to do when teh part is already dialed in. CAD (solidworks in our case) also helps our team determine how much we weigh. (sually light be 5 lbs). I believe that any project that involves machining should be done in CAD. You willl find out that a "real" engineer is required to build their project in CAD BEFORE it hits the machine shop. There is no such thing as a drill.
K.I.S.S
Keeping It Simple Stupid
Unread 24-02-2006, 07:41
Henry Anthony Henry Anthony is offline
FRC #1250 (GATORBOTS)
Henry Anthony is on a distinguished road
Thank you all for your helpful responses. On 1250, no one even knows there is an Inventor award. I guess that tells you how important CAD is on the team.
In defense of the team, there is a shortage of computing facilities to perform this work so a single designer is doing it at home. More an exercise in documenting the design rather than design to build.
As this was posted in the CAD section, I am not surprised to find that most of the responses were on a positive note. Maybe I'll try in the general forum and see what happens.
Good luck with all your entries!
Best regards,
Henry
Unread 24-02-2006, 08:09
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
I believe the CAD drawings are very important to design. Our mentors however did not think it was. So when we came upon the problem of not having the right wheels because we were making the robot basicly as we went we had run into the issue and had to reorder wheels. Needless to say for all those who don't think its important there is a prime example. That and if you are really savy about using it you can model everything down to bolts and wires and can generally get to know your robot very well even if it is shipped off
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
Unread 24-02-2006, 21:43
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: Does CAD get respect on your team?
Inventor important to some extent. There have been plenty of times when we've saved hours of work by using Inventor. But the problem is when you make slight changes like drilling a hole here for weight, or simply throwing a part out and quickly cutting another one takes a lot less time. These quick changes put designers behind the manufacturers, and then catching up with a manufacturing team that usually has 3 or 4 times as many people on the design team it's impossible. Complete robots, including electronics, pneumatics, animations are all things that take so little time compared to Inventor. Also most teams work till the last minute, then when the robot is gone it's impossible to get measurements. All of these factors lead to the impossibility to use Inventor completely. I will say team 103 used inventor a lot. We designed every one of our prototypes, and even used it to lay out a schematic for electronics. This was due to successful communication and working along with our manufacturing guys.
2005 2006 2007 Autodesk Inventor Winner
2005 Winning Site & 2006 Winning Site
2007 Winning Site
Unread 24-02-2006, 21:48
Bharat Nain's Avatar
CAD is the oxygen for engineering. It's the baseline for all that we do -- atleast to start. It helps us see things we would not without designing.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 24-02-2006, 22:39
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
CAD? What's CAD?
Really our team is starting to use it more. Part of the problem is that we build before they can CAD an idea. As the students improve I am sure that it will become a starting point not a middle ground.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 25-02-2006, 09:08
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
I definitely agree here. On MORT, we design a lot of our parts in CAD. (With the exception of our frame which was drawn out and mocked up entirely using cardboard.) We have electrical diagrams, CAD files of any parts that have detailed machining (mostly so we can CNC) and I think that this year it really got out to the masses as both the end effectors and drivetrain teams used CAD people and software to help their design process.
On the otherhand, quick fixes (weight holes, corner rounding, last-minute changes) are done without design work in advance, leaving the CAD team to walk into the shop everyday to ask "What did you change today?"
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 25-02-2006, 19:30
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
For us, CAD(Autodesk Inventor) was become the golden rule. It has given us two ubercool chassises that are awsome. The arms are a different story. But yes, CAD gets massive props on our team. If you have'nt done so, have you been living under a robot?!
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 25-02-2006, 21:09
peaseonearth's Avatar
peaseonearth peaseonearth is offline
Dream me up a future
AKA: Patrick Pease
FRC #0176 (Aces High)
Team Role: Driver
peaseonearth has a spectacular aura aboutpeaseonearth has a spectacular aura about
Send a message via AIM to peaseonearth Send a message via Yahoo to peaseonearth
Without Cad on our team, no robot would ever be mad. For the past 3 years now the robot has been completely made on cad before made in real life. This helps do it right the first time and gives the students real life experience in designing parts for most anything.
Aces High
BU '11
"We Change the way the World works"
Unread 25-02-2006, 22:21
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
Yes CAD is very important on our team. It helps everyone see their ideas and also helps save alot of money when it's time to prototype. I personally don't do much CAD and work but I do do alot for FIRST which helps keep me on top of these skills if I ever need to use them for work.
E
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
Unread 26-02-2006, 13:53
orelinde's Avatar
orelinde orelinde is offline
Parental Unit
FRC #1733 (Polarbots)
Team Role: Parent
orelinde has a spectacular aura aboutorelinde has a spectacular aura aboutorelinde has a spectacular aura about
sadly our robot seemed to be built before cadd was even mentioned. My son was the only one who tried to cadd but it is so hard with 7 sets of hands building and only one cadding. we took lots of pictures but overall as a rookie team cadd was not really used. now Paint on the other hand was used in the design as it is simple, clear, to the point, and everyone on the team understood it instantly. now we are working on the cadd more as a documentation of what the team went through to get what it has now.
I hope that next year CADD will take a larger part in the design but it is hard when all the kids really want to do is build.
He walked so quietly i could have shot him in the dark...so I did then laughed my tush off.
And you call me strange like it is a bad thing?
I took a test that says I am a geek, My son took same test he is an extreme geek. I am so proud.
Unread 27-02-2006, 15:03
Back in the Game
AKA: Ed Venator
FRC #2399
I suggest you guys do some summer classes in CAD because your teams seems really eager to use computer programs to draft designs, but just doens't have the knowledge. Once you know inventor, it's really easy to use, so I think that a few classes from a mentor or student on the team could really help out.
MORT 11
HB 2399
Unread 27-02-2006, 19:10
Daniel Morse Daniel Morse is offline
former 213 member
FRC #0213 (The Dirty Birds)
Daniel Morse is a jewel in the roughDaniel Morse is a jewel in the roughDaniel Morse is a jewel in the roughDaniel Morse is a jewel in the rough
Team 213 relies on Autodesk Inventor from the beginning until the end of the season. The two student design leaders (a friend and I) are the lead Inventor modelers on the team, and are often doing most of the modeling the parts. I also teach the younger members how to use the program, and I am pleased to say that they were very enthusiastic about it. Inventor is a very powerful and useful tool that has streamlined the efficiency of our manufacturing process.
Rensselaer Polytechnic Institute class of 2010 - Mechancial Engineering
Student and Mentor, Keene High School Team 213 "The Dirty Birds" 2003-2006
College Mentor, Team 1493, RPI and Albany High School "The Falcons" 2008
Unread 27-02-2006, 22:50
plutonium83
Posts: n/a
On our team, if you wish to make a major modification to the robot, you must fully draw it in CAD first.
Unread 28-02-2006, 16:31
Anubuss's Avatar
Anubuss Anubuss is offline
AKA: Brian Dixon
FRC #0085 (B.O.B. (Built On Brains))
Anubuss will become famous soon enoughAnubuss will become famous soon enough
Send a message via Yahoo to Anubuss
CAD is all well an good, but personaly, our team uses Solid Works, and thanks to one of our engineers, we have a whole computer room with it loaded on every one.
East Coast Drivers Union Corey Balint FIRST-related Organizations 153 10-04-2006 15:50
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
CAD on your team? SpaceOsc Inventor 25 18-11-2004 11:14
Kettering Kickoff Matt Attallah Off-Season Events 19 27-09-2004 22:40
