Go to Post Although it is tempting, try not to toot your own horn in this thread. While you may have an awesome bot, the real compliment should come from other teams. - Andy Baker [more]
Go Back   Chief Delphi > Other > Car Nack's Corner
  #31   Spotlight this post!
Unread 12-02-2006, 21:00
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Car Nack Predicts 3/06
Originally Posted by Billfred
Perhaps the simpler solution is to use a nice and natural part of the planet to our advantage: gravity.
If you can tilt a robot so that it shoots vertically and measure the height from floor to shooter in centimeters, you can have it fire a ball and time how long it's airborne. Throw in some simple math, and bada-bing, you can tell in about ten seconds whether it's legal on the velocity side.
In fact, I'm sure Kevin Watson has been hiding in his workshop doing some black magic with an old RC, some limit switches, and a piece of string cheese to accomplish just that.
You forgot about the flux-capacitor that warps local space-time <grin>.
-Kevin
Kevin Watson
http://kevin.org
  #32   Spotlight this post!
Unread 24-02-2006, 23:07
lil_longo's Avatar
lil_longo lil_longo is offline
AKA: Brian
FRC #1676
Team Role: Mascot
lil_longo has a spectacular aura aboutlil_longo has a spectacular aura aboutlil_longo has a spectacular aura about
Send a message via AIM to lil_longo
i agree but how are they going to check that? are they going to take some radar guns and test the speeds before each match i think its going to take to much work to stop that
  #33   Spotlight this post!
Unread 24-02-2006, 23:25
Billfred's Avatar
Billfred Billfred is offline
From Q&A: http://forums.usfirst.org/showthread.php?t=725
Originally Posted by GDC
FIRST is planning to use a two-point infrared speed trap to determine ball exit velocity. These units will be delivered to each competition site.
  #34   Spotlight this post!
Unread 25-02-2006, 00:10
dubious elise's Avatar
dubious elise dubious elise is offline
Gone to school, back in 2016
FRC #0269 (Cooney Robotics); FLL #1855 (Cooney Tech/St. Jerome)
dubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond reputedubious elise has a reputation beyond repute
Just out of curiosity, couldn't FIRST ask an organization like the USTA or MLB to donate some ball-speed measuring devices? Think about it, in almost every tennis or baseball event you see on tv (and probably a few other sports as well, I just can't think of them offhand) they give the speed that the ball was served or pitched at. If those guns can record speeds up to 150+ mph, they certainly must be able to handle 26.8 mph, right?
And it is a bit of an off-season for both sports, so...
"We can't guarantee success...but we can do something better, we can deserve it." ~John Adams
"The harder you work, the luckier you are." ~Gerald Ford
Notre Dame '10
  #35   Spotlight this post!
Unread 25-02-2006, 22:31
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Greg Needel
I am personally a fan of the radar gun.
Umm, what about a beam-break sensor? Super simple to build, just as easy to calibrate, portable, battery-powerable, and will work with any shooter.
In case the idea isn't clear: Think of a tube a few inches (maybe a foot) long. Have someone shoot their ball through the tube. In the tube is an emitter (of light) and a sensor (on the sother side of the tube). Simply measure the time that a 7" ball breaks the beam (a few milliseconds) and you have a speed. Of course, the exact size of the ball needs to be measured, and an accurate timer needs to be used.
On the other hand, ask any experienced police officer, they will tell you they can judge the speed of a car to within 2 or 3 miles per hour, just from experience. I'd bet the referees develop a similar feel for speed, and will send teams back to the inspectors often.
Don
  #36   Spotlight this post!
Unread 28-02-2006, 17:09
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
You've been reading people's minds/posts, haven't you?
Vince Wilczynski in this post proposed the very same thing. Vince's setup uses 2 IR sensors (Emitter/Sensor combo, I recognized it as having been shipped in FRC kits sometime in the past 2 years), one at the start of a "tube" and the other at the end, and uses LabVIEW and a USB-DAQ device to measure the speed of the ball traveling through the tube (measures the time between the normally-low digital response from the sensors go "high"). It's not battery powered to my knowledge, but could be. And it's very effective, Vince said his tests worked out fairly well at a "mini-meet" he tried it out at.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
  #37   Spotlight this post!
Unread 28-02-2006, 17:14
Danny,
The official word is it will be a setup like the one you describe, or something similar. I recall seeing it on CD, in fact, it's referenced higher up in this thread.
  #38   Spotlight this post!
Unread 28-02-2006, 17:41
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Aha! So it is, I don't know how I missed that gem. It would be nice if NI Pilot Program teams (with the means to do so) would build one of these for people to use for spot-testing at their regional. If anyone wants "general" plans for one of these or the LabVIEW program I'd be happy to help out...
-Danny
Danny Diaz
  #39   Spotlight this post!
Unread 28-02-2006, 21:11
I have it on good authority that devices are under construction as we speak and will be shipped to each event.
  #40   Spotlight this post!
Unread 28-02-2006, 22:19
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
First question...is everybodies shooter shoot the same speed with every different ball in various states or destruction...i know we sure dont
Second question...unless a robot lines up to the edge of the field and delibertly shoots a few balls off into the crowd would the impact of a ball that most likely was lobbed into the crowd be that much of a safety hazard to the normal person (i say this because there may be some special cases where it could be dangerous such as an infant etc.) but how many of these cases do you see in the typical crowd.
just some things to think about
MechWarriors 573
Car Nack Predicts #4 Car Nack Car Nack's Corner 1 14-04-2005 10:57
Car Nack Predicts #4 Car Nack Car Nack's Corner 0 29-03-2004 11:18
Car Nack predicts #3 Car Nack Car Nack's Corner 2 03-03-2004 09:24
Car Nack Predicts #2 Car Nack Car Nack's Corner 1 06-02-2004 12:48
Car Nack Predicts Bill Beatty Off-Season Events 4 11-11-2001 12:12
