Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 28-02-2006, 18:34
pyro20911d
Posts: n/a
neon/strobes on bot
Does anyone know the rules/guidelines for having lights on the bot other than the ones provided?
I know that you can't use the green cold cathodes supplied in the kit=no brainer.
Unread 28-02-2006, 18:44
Dan9874123's Avatar
Dan9874123 Dan9874123 is offline
FRC #0236 (Techno Ticks)
Dan9874123 can only hope to improve
Send a message via AIM to Dan9874123
Re: neon/strobes on bot
I think anything that would act to distract the cameras would be out of the question. Strobe lights would probably be out as well. Maybe something like underglow but I doubt it.
"Better to remain silent and be thought a fool, than to speak out and erase all doubt"
Abraham Lincoln
Unread 28-02-2006, 18:47
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
All I can say is check the rule book.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 28-02-2006, 19:00
pyro20911d
Posts: n/a
I f there isn't a rule against it, does that mean it will fly?....like if just for kicks, i wanted to put a fog machine on our bot....there obviously isn't a rule against that........................and no, I'm not serious
Unread 28-02-2006, 19:01
EricH EricH is online now
Gotta be powered by the main battery via a 20 or 30 amp breaker and not be green. They are classed as NFDs (non-functional decorations) unless they are jamming opponents' vision systems, in which case they are classified as illegal. Section 5.3.11 has more details. You can't break weight or size limits.
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
If you are planning on using any green lights, please don't do that. I think it will be against the rules.
If you are thinking about using lights (red, blue or any other) to decorate your robot, you should be fine. Keep in mind that during inspection you will need to include all your decoration when you weigh your robot.
Unread 28-02-2006, 19:05
pyro20911d
Posts: n/a
thanks.. I don't have a rule book on hand..I'm working on some ideas to make our future bots a little flashier ///no pun intended///
Unread 28-02-2006, 19:42
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
I believe that particular argument would be illegal due to blocking the drivers' view.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 28-02-2006, 19:46
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Umm... try USFIRST.ORG
Unread 28-02-2006, 20:02
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
i believe there is a rule that you can only use the LED lights provided, most likely to prevent teams from trying to distract the opponents drivers, and to not impair vision as to gain an unfair advantage
Blargha!
Unread 28-02-2006, 20:06
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I'd say strobes are out of the question for matches just because of their potential to distract drivers and/or cause seizures. underbody lights, as long as they're not green, are probably fine as long as they don't flash too brightly. I'd suggest just some LED's/cold cathode tubes mounted on the underside of the robot just to cast a soft glow on the carpet.
Unread 28-02-2006, 20:09
in between teams
AKA: Luke Van Oort
Don't use red or blue unless you can change colors quickly. Those are reserved for alliance identification.
Team 1219: 2009 - Mentor
Unread 28-02-2006, 20:42
Please read the robot rules again and reference the exact rule if you find it.
lukevanoort, there is no reservation as to color that I know of, save that you can't use green similar to the lights.
Unread 28-02-2006, 20:52
Answer,
5.3.11 Non-Functional Decoration Rules
Teams may add “Non-functional” decorations to robots under the following conditions:
<R101> Decorations must be on the robot at the time of final inspection, and must not cause the robot weight or
size to exceed the Rule requirements.
<R102> Decorations must not affect the outcome of the match, and must be in the spirit of “Gracious
Professionalism.”
<R103> Any decorations that involve broadcasting a signal to/from the robot, such as remote cameras, must be
cleared with FIRST Engineering prior to use. Teams may not use 900 MHz camera systems.
<R104> Decorations may draw power from the 12v electrical system as long as they are powered via a dedicated
20A or 30A circuit breaker and do not affect the operation of other control system components.
Additionally,
R31> No devices or decorations are permitted on the robot that are intended to jam or interfere with the
operation of the vision system (i.e. changing robot color to confuse opponent’s vision system).
Apply the flowchart as needed.
Unread 28-02-2006, 22:12
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Technically, I dont think that blocking driver view is illegal...just not all that GPish.
www.metalmoose.com
sphere bot Veselin Kolev Technical Discussion 36 03-03-2005 00:03
kit bot wireing sirbleedsalot Electrical 5 27-01-2005 17:59
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
