Go to Post Who needs weapons when you have a scary face - Conor Ryan [more]
Unread 26-02-2006, 22:16
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Re: IFI loading problems
Do you mean delete registry entries or delete files from windows explorer.
Unread 26-02-2006, 23:31
Eko's Avatar
Eko Eko is offline
Eko is an unknown quantity at this point
Registry entries
Unread 28-02-2006, 16:36
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Are you downloading via real serial port or usb-to-serial converter? If usb-to-serial converter check that the com port number didn't change when the flash drive isn't plugged in.
Unread 28-02-2006, 19:10
FRC #0935
I am using a serial port.
Unread 01-03-2006, 16:58
FRC #0935
Ok I tried a new flashdrive, a very old one that I reformatted and it worked. The program downloaded correctly. That is very wierd. So its not a file on the flashdrive that it needs it has something to do with the port itself. Any help?
Unread 01-03-2006, 17:04
Umm Errr...
can you open a connection to the robot in hyperterminal and view the output from printf statements without the thumb drive? You will need to set the settings to:
115.2K baud
data bits: 8
parity: none
stop bits: 1
flow control : none
If you can do this then you know it is an ifiloader problem and not something stranger.
What model is you laptop? I have a suspicion that maybie you do not have a "normal" serial port.
I think eko's explanation is the most likely
1139 Alumni
Unread 01-03-2006, 18:46
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Just wondering... have you directed IFI loader to COM 1? (or whatever COM port you are using)
When you install it try to create a new directory such as IFI_loader2 or something like that. We have the old version installed and the new one in the IFI_loader2 directory.
Eat, Sleep, Build Robots
Unread 01-03-2006, 19:14
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
115K baud
8 data bits
1 stop bits
flow control : none
[I was just trying to think how he might be able to use Hyperterminal to deterine the problem, since it seems like a comms problem.]
Yes. Try doing as James (Rickertsen) says (if you can find your way around Hyperterminal. )
Another thought: Hyperterminal will tell you what com ports are available. (Click on the "Connect Using" drop down list in the connection Properties dialog.) Try this both without the flash drive plugged in, and with it.
Unread 01-03-2006, 20:42
FRC #0935
115K baud
8 data bits
1 stop bits
flow control : none
We have a Dell Latitude 505. I'll try the hyperterminal thing at our next meeting. Also I manually deleted every file and registy entry I could find that had anything to do with ifi loader.
Unread 05-03-2006, 18:16
sur2124 sur2124 is offline
FRC #0116
sur2124 is an unknown quantity at this point
I agree, if that dosn't work resave the program so it's on your C drive.
Unread 06-03-2006, 17:21
FRC #0935
I tested it with hyper terminal and it does not show printfs when the flashdrive if unplugged but when it is plugged in it shows printfs.
IFI Loader problems Hieb Programming 3 18-01-2005 13:45
IFI Loader problems billstu Programming 22 23-03-2004 11:39
IFI Loader Problems lasindi Programming 6 05-02-2004 06:06
IFI Loader Problems BrendaB Programming 3 24-01-2004 22:45
