Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Unread 01-03-2006, 01:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Aluminum Gears
20 pitch (or even 24 pitch) aluminum spur gears. 3/8" or preferably 1/2" face width.
Rino is the only place I've found that has what I'm looking for, but I still need to find out their price.
Berg has only 16 pitch as far as I know
SDP-SI has 24 pitch but only in 3/16" face width.
Let me know if you know of anywhere that has them.
Unread 01-03-2006, 01:55
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: Aluminum Gears
Call around to local gear shops and have some custom made. Our gear shop has offered to make use AL gears for the last few years but we never went thru with it because we didn't feel the weight savings would be worth the possible strength issues.
Kirk
Unread 01-03-2006, 03:22
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Aluminum Gears
You want to be careful with Aluminum gears. You would probably want to use 7075 or 2024 aluminum, and hard anodize, or preferably titanium anodize the gears. From what we were told in the past, tiodizing creates a hardened surface without increasing the parts dimensions (as hard anodizing does). Just something to take note of, as we have been looking into the same thing.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 01-03-2006, 08:29
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Aluminum Gears
By the way, the hard anodizing process on some aluminum gears is applied before cutting the gear teeth, not after. Don't count on getting any extra surface durability on the teeth itself, when you order off-the-shelf anodized gears.
I haven't used it, but I think that Travis is referring to the Ematal process of titanium anodizing; I've heard good things about it. Look in an ASM Handbook for details on the process.
bolting square aluminum without crushing walls greencactus3 Technical Discussion 11 20-01-2006 16:58
request for info on gearbox gears jskene Technical Discussion 0 08-01-2005 18:07
Looking for gears from BostonGear in Inventor.. geo Inventor 6 05-08-2004 10:07
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
Difference in aluminum archiver 2001 1 23-06-2002 23:49
