Go to Post It's 9:00 Do you know where your bott is? - Michelle Celio [more]
Unread 01-03-2006, 03:56
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: How do you manage code changes?
That is what we do for the most part. The merge is made much easier by
using a contextual diff tool that visually shows which files are different, and
helps us merge the files.
Originally Posted by Donut
We use a set of folders with different version names, and a good old USB drive. My job this year (other than doing a few tasks that had to be finished) was pretty much merging code and making sure everything got coded.
We should probably invest in something else though.
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
