Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 26-02-2006, 15:02
TriggsJr TriggsJr is offline
US FIRST made me an Engineer
None #0173
TriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to all
Send a message via AIM to TriggsJr
pic: Fisher price on steriods???????????
Unread 26-02-2006, 15:03
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Re: pic: Fisher price on steriods???????????
Oh My!, you must post some internal pics. PLEASEEEE
Hows my searching? Call 1-800-Green-Dots
Unread 26-02-2006, 15:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A bit scary (all those plastic gears) but nonetheless very interesting and quite useful in the right application.
Unread 26-02-2006, 15:14
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
You know what scares me more than the idea of actually managing to shove two FP motors into the same plastic gear box is that they're wired together. Infact it looks like if you drive one the other will cause it to send a reverse current back to the other, causing it to lock up. But i'm sure you know what you're doing. I'll be at your pits in hartford to demistify this conundrum
Team Website
Unread 26-02-2006, 15:23
They are nylon, and most of the motors you get in the kit of parts that have worms or GB's on them have nylon in them
Unread 26-02-2006, 15:25
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
We did that on our 2004 robot for our ball collector and it worked fine through three regionals, nationals, and three offseason events
-Paul
Unread 26-02-2006, 15:26
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Don't you want the motors to spin opposite each other if they are meshed with the same gear?
I believe they are shorting them on purpose, looks as if they are using them as a brake?
Unread 26-02-2006, 16:13
Specialized's Avatar
Specialized Specialized is offline
Student-Parent Liason/I make stuff
AKA: Chris Riedinger
FRC #0195 (CyberKnights)
Specialized is a jewel in the roughSpecialized is a jewel in the roughSpecialized is a jewel in the rough
Send a message via AIM to Specialized
Yes, when you "short" these motors together, they provide what is called an electrical brake, in which one is essentially a generator for electricity which "powers" the other motor, essentially causing them to turn in opposite (or the same) directions, whichever way you have them wired.
Unread 26-02-2006, 19:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Nope. If you have two motors geared to the same gear, then there would be an odd number of gears between the motors - resulting in both motors spinning in the same direction.
You know what scares me more than the idea of actually managing to shove two FP motors into the same plastic gear box is that they're wired together. Infact it looks like if you drive one the other will cause it to send a reverse current back to the other, causing it to lock up. But i'm sure you know what you're doing. I'll be at your pits in hartford to demistify this conundrum ;D
I may not be the person who designed this, but the initial stages of a gearbox carry mostly speed and with little torque. As you increase the number of stages in a gearbox, more and more torque is transferred, and that is why the pitch of the gears decrease. The less teeth you have per inch, the larger the teeth get, and the more torque they can transfer.
This gearbox is going to have a lot of output power, as the two FP motors together are a little less than one-half horsepower, which is about the same as a CIM motor. (2 FP x 170 watts = 340 watts.) From this side picture, it looks like you have the auxiliary FP motor geared into the first stage from between the plastic ribs under the third stage. (The blue part is the original FP motor, and the red is the auxiliary FP motor.) Am I correct in this assumption?
Art Dutra IV
世上无难事,只怕有心人.
Unread 26-02-2006, 20:14
the_short1's Avatar
the_short1 the_short1 is offline
Head of Electronics
AKA: Kevin F.
FRC #1596 (Twin Saults International Instigators)
Team Role: Electrical
the_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to allthe_short1 is a name known to all
Send a message via MSN to the_short1
that looks REALLY REALLY cool. would love to see a power curve for that bad boy
2005 GLR: 12th/58 Seed, Aliance: 1596, 910, 1447 (Semi Finalists) Website, Rookie All Star, Highest Rookie Seed, and 2 Peer Awards, my BIG thank you thread, PLEASE READ
2005 GTR: 11th/66 Seed, Aliance: 703, 1596, 1680 (Semi Finalists) Highest Rookie Seed & 1 Peer Awards
2005 Championship (Galileo): 36th/86 Seed Highest Galileo Match Score: 123:7 Thanks 447 and 121
2006 Website (Totally Revamped):Instigators1596.com
2006 GLR: 31st/61 Seed, Aliance: 835, 1213, 1596 (Quarter Finalists) Spirit & 3 peer awards, THX!
2006 Waterloo: 7th/31 Seed, Aliance: 1219, 1596, 912 (Semi Finalists) Spirit & 2 peer awards, THX!
2006 Waterloo: Aliance: 1596, 1680, 1114 Higest Match Score: (Q22) 128|32
Unread 27-02-2006, 15:45
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
last year we burned our fp's and the following saying was born:
ahh... nothing like the smell of fisher prices in the morning
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 27-02-2006, 18:34
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
ahh yes...love that smoke...
neat gearbox. it's something we wouldn't think of. (we'd prolly spend twice the weight on a custom gearbox made out of something heavy like aluminum)
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 28-02-2006, 23:25
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
The FP's pull cool air in front and exhaust it out the back. The original FP gearbox has two holes that go all the way through and a slot in on the back side of the gearbox to provide cooling air. Did you add the spacer between the second motor and the gearbox to allow air to get to the front of the motor?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 01-03-2006, 08:33
None #0173
No its just a spacer.
Cost of Fisher Price Motors? ChuckDickerson Motors 2 12-06-2005 13:44
pic: RIP Fisher Price Motor ZZII 527 Robot Showcase 6 22-02-2005 15:56
Fisher Price pinnion specs? atmaturen Technical Discussion 1 12-01-2005 19:39
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
Last year vs. this year Fisher Price Gear bmusser Technical Discussion 4 29-01-2002 13:24
