Go to Post There is no such thing as "un-GP." - Tetraman [more]
Unread 01-03-2006, 22:07
Umm Errr...
Re: How does your auto-aim work?
Originally Posted by Don Rotolo
Camera is mounted to the pan table, a PI loop (No pun intended, but no D either)...
Don
Why PI instead of PD or PID?
1139 Alumni
Unread 01-03-2006, 22:10
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Have any of you tried aiming your shooter without auto aim? I found it easier than I thought (in practice, anyway) to line up the robot to score from the base of the ramp. I don't think we're going to be accurate enough to score on the other end of our parabola, but from the base of the ramp we didn't have too much difficulty visually gauging whether we were in place or not.
Now autonomous...
Unread 01-03-2006, 22:22
Happy Birthday! JonBell JonBell is offline
None #0546 (Technotics)
JonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really nice
Send a message via AIM to JonBell
Now autonomous...
Actually, now that you mention it...
Due to a number of technical fowl ups (including robot not being done on time, programming team degrading to just myself, and school being closed during last the last week, forcing our pickup to be the friday before), I spent a few hours playing with our robot with just the manual controls. I have had no problem adjusting the altitude (I made a knob that scales the shooter from max legal range to min to reach target), and pretty much always hit the right horizontal, but as distance increases, it's harder to line it up centered. Hopefully during the fix it window I'll be able to program the camera to stay fixed and just tell us when we're in the left-right sweet spot (it seems like this should be relatively easy).
One thing that I noticed with all of these auto-locator robots is this:
Will you have had enough practice shooting without your camera assistance? It seems like (on most robots), the camera is mounted below the shooter, making it very easy to get in between it and the vision target, a defense that may prove to be very successfull.
Unread 01-03-2006, 22:29
I've always thought it was a rule of thumb to use PI for position control and PD for velocity control, especially with the dead band on the victors.
In position control, you want to accurately stick to one position. (yeah, I know... duh... ) With just P control, the error can get so small that you are sending a output of 0 (-10 - 10 - victor dead band) to the motor control. You want the integral term to look at that error building up and over power it.
In velocity control, you want to change your output on the fly, and compensate for where you think you need to be. PD works fine.
Unread 01-03-2006, 22:58
Umm Errr...
Maybie i am mistaken, but it thought the opposite was true and you were suppsoed to use PD for position and PI for velocity/temperature. It seems to me that when controlling velocity, I would be very important because it ends up canceling out friction and other forces that would prevent P alone from reaching the setpoint. It seems like D is very important in a position control system because it makes the system stable. If you model a perfect frictionless system with a position P controller applying a force to a mass, the system will oscillate in a sinusiodal fashion. If you add D, it becomes stable. You make a good point though about I eliminating the steady state error.
In my PD code i have a minimum output signal that the controller is allowed to output so long as the controller is outside of its allowable tolerance. This minimum is just enough to overcome friction, the victor deadband etc.
Perhaps i should code in an I to my control loop.
Obviously PID is the ideal solution.
1139 Alumni
Unread 01-03-2006, 23:04
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Yeah, if you don't mind losing your mind trying to tune it.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 01-03-2006, 23:17
Umm Errr...
true that
1139 Alumni
Unread 06-03-2006, 16:28
Don Reid Don Reid is offline
Don Reid will become famous soon enough
Our camera is bolted directly to the robot frame, no pan or tilt. It is in line with the cannon.
We mechanically align the camera to have the target at the center when the cannon shoots balls through the center of the goal from the desired position.
In use, when the driver requests it, the firmware uses a PID loop (sort of 2, for X & Y) to drive the robot until the center of the target is at the center of the camera.
We also have a custom dashboard program that shows the driver(s) where the camera sees the target. They use this to decide when to activate the auto method, or for manual aiming.
Don Reid
Unread 07-03-2006, 17:22
mogunus mogunus is offline
AKA: Luciano DiFalcone
FRC #1350 (Rambots)
mogunus is an unknown quantity at this point
We use two cameras, each mounted on the pan/tilt servo, one on either side of the shooter, to "triangulate" the range to the target. Generally, the range estimate we get from that is accurate to within 5 inches. That gives us the x-vector that we need to plug in to the launch angle formula, given the constant Y-vector and the constant speed that we hold our shooter motors at.
This approach works well.
... one of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
-- Robert Firth
Unread 07-03-2006, 17:48
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
We'll find out this weekend how (or whether) our auto-aim works.
We fix-mounted our camera such that at the base of the ramp, the target is at the top of the camera's field of view, and at half court, it is at the bottom. Based upon the Y position of the blob centroid, we calculate (actually lookup) the required shooter speed. We also have an auto-aim driving mode which uses the blob centroid's X position as input to a PID control loop to get and keep the robot pointed at the goal.
Unread 24-03-2006, 04:13
Ben Englert Ben Englert is offline
FRC #1072
Ben Englert has a spectacular aura aboutBen Englert has a spectacular aura aboutBen Englert has a spectacular aura about
How do you hook up two cameras to the RC? Do you just use the program port for one, or have you put together some kind of multiplexer?
Before a match at SVR, 3/17/06
Tatsu: "Yo Englert, what's our autonomous mode?"
Me: "We'll find out, won't we."
Both: *maniacal laughter*
After the match's autonomous period ends:
Me: "Well, the basic control system still responds. That's always good."
Both: *further laughter*
Unread 25-03-2006, 23:18
Neo3One3 Neo3One3 is offline
AKA: Nick
FRC #0175 (Buzz)
Team Role: Driver
Neo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to allNeo3One3 is a name known to all
Well, for ours, we use two functions, one for pan and the other for tilt (obviously). For our tilt, we simply use a lookup table based on the camera's tilt servo position, and drive the motor to a certain pot reading accordingly. For our pan, we set a zero position for when the camera is centered to the turret, and the turret drives until that center is reached.
Mogunus, I was wondering what the reason was for having two cameras. Can't you simply get the distance to the goal from:
Distance to Wall = Height from Camera to Light / Tangent(Camera Angle)
and
Distance to Goal = Height from Camera to Light / Cosine(Camera Angle)
Maybe accuracy increases from two cameras, I'm not really sure.
Go Buzz!
Unread 26-03-2006, 00:08
lemoneasy lemoneasy is offline
AKA: Evan Crawford
FRC #1334
lemoneasy is on a distinguished road
accuracy could increase with two cameras if you have a problem with it tracking through a few pwm positions in the tilt of the camera. If your out by center field, that makes a big difference in calculations, so you could use the average angle from both cameras to get a better reading, but it would be more efficient to just take the numbers from two loops and average.
For our bot, we had an auto-aim that was working perfectly, but when you get to competitions and the bright lights drown out the targets, its a lot more unreliable. 220 confidence to 20 more unreliable. It also is a pretty large target, but if your shooting from further away, its nice to have auto-aim.
We had a tilt and pan motors, each powered by relays, the pan was just a number based on the servo position of our camera it drove until the pot had the same number (after conversion, the pot was 16-bit). Same with the tilt, based on the distance to the wall, we found an angle, which was converted to a postition on the pot, and driven to it, as long as it was within the limits.
Thats about it, not overly complex, and with these large nets, aiming is pretty forgiving.
Unread 27-03-2006, 00:52
iamthetallpaul iamthetallpaul is offline
FRC #1189
iamthetallpaul is on a distinguished road
I wish I had had more experience to learn about PD, PID, and PI loops, this was my first and only year as our only programmer (any my only year on the team). Th last one graduated and left me with nothing.
I used a slightly modified version of Kevin's code. Instead of driving a pan servo based on the pan_error, pan_error is just added to or subtracted from 127 to drive the turret motor towards the center of the light. Actually slightly off center since the camer is mounted off center. Tilt is exactly the same and the hood is a lookup table.
Unread 27-03-2006, 01:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I am not a programmer but I'll explain it to the best of my abilities. Our robot has azimuth and elevation control on the shooter. We have pots on both. The camera has it's own azimuth and elevation control (the one provided in the kit) using servos. The camera is mounted to the shooter azimuth but not the shooter elevation. When the aim button is pressed, the camera searches for the target. When the target is found, it locks on. Then, the "brains" say "okay, where are my camera's servos pointed right now?" and "where do my shooter's pots say it is pointed right now?" and "why the heck aren't they pointing the same way?" and "let's make them point the same way." This all happens in about half a second. That is a non-programmer's description of it. Anyway, because of our turret, we can be pushed around and still be locked onto the goal. At the SoCal regional, it worked so well we won the Radio Shack Innovation in Control Award for it. However, after we won that award, teams came up with autonomous modes (ramming) specifically against us. When they hit us hard, we remained dead locked on the target, but the balls in the feeder mechanism jammed, and we could not use our unjamming function until driver control mode. In one of our Saturday qualifying matches, we made some really long shots, from our low down shooter even with robots trying to block us because we could reposition and still be locked on or easily lock on again.
Also, on our feeder mechanism, we have a light sensor so when the light beam is broken, the motor stops until the "fire" button is pressed again. This allows indexed feeding and control of exactly how many balls we shoot.
What Artist Influence You? Koko Ed Chit-Chat 12 01-12-2006 11:33
Springs and Work sanddrag Math and Science 11 17-05-2005 18:35
(part II) We aim for the stars Ken Leung General Forum 6 03-05-2005 16:57
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
