Go to Post We can't turn off inspiration and recognition, development and learning with a switch. It is an on-going process. If it were not, there would be no need for CD except for 6 weeks out of the year. - JaneYoung [more]
Unread 02-03-2006, 00:17
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Dashboard Port Decoder
If I had a 2003 OI hooked to the 2003 FRC, could I still have data in from the 2006 dashboard port? Wouldn't the OI be taking the tether port which is where i would have data coming in? Could I take the data from the dashboard port on the 2006 OI and send it to a digital input on the 2003 FRC? Why does the 2003 FRC require a OI if I am using the other data as an "OI"? I guess I am just clinging on to hopeless thoughts here. I am probably going to have to get an EDU-BOT PIC controller. If I got one, how would I interface the data from the dashboard port in C (there is no SERIN in C, at least not that I know of.)
Jacob Komar
Revised Comments:
I guess I overlooked part of your previous post. If I used a previous years FRC, that would be all that I need. How would I specify what I want the input to be on the serial port though, if I'm programming it in C? That would be easy in PBASIC, because I could specify it using SERIN. I am not greatly familiar with C, so maybe there is a way to port the bytes to variables.
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
