Go to Post Math, it's great stuff - AdamHeard [more]
Unread 02-03-2006, 20:04
Umm Errr...
Re: Dashboard Port Decoder
Originally Posted by whytheheckme
I removed all of the code afterward, so it's not hanging up there. Even if the baud rate is wrong, shouldn't it still try to recieve data? If I unplug the dashboard cable going to the program port, it still gives me the error. Should it do this? Where can I find out about that port 16 thing?
Jacob Komar
the port 16 thing is mentioned in the serin section of the basic stamp manual. 16 is a special number that actually means pin 2 which is the pin used for programming the stamp. This should be the one connected to the "program" port. The manual is vague, but apparently 16 also offers some sort of enhanced hardware support for receiving serial data.
1139 Alumni
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
