pic: 1341's 2006 Robot
Re: pic: 1341's 2006 Robot
What's the third wheel below the shooter for?
I love the speed holes! |
it apears to be their redneck version of gears
P.S. love the speed-holes |
Um no...
to me it looks like the third wheel is powering the small wheels and then the two of the small wheels are on the same shaft as the shooter wheels. Team 1341 used wheels to power their shooter instead of sprocket, chains or even gears. |
#7
nice bot. except it seems to have a high COG
![]() does the shooter take a considerable amount of time longer to get to target RPM? the wheels to distribute power is a great idea but wont they slip? i guess it should somewhat similar to belts. good job though. another team to add to the "tough competition" category. UCF is gonna be really exciting someone seems to have had waaaay too much fun with a drill. |
#8
ooh what's the robot called? Flamin Hot?
I like the technical look of it, and you can never go wrong with the color red or with speed holes -Pavan |
#10
Wow, I really love that conveyor track you guys used to get the balls from the floor up to the shooter. We actually looked into that stuff but decided against it due to weight issues with our available hardware. I never imagined it would be used the way you guys did it, but I am really impressed. Great job guys, I can see you put a lot of time into the design. What an incredible, and beautiful robot!
#11
I love the cheeseholing, especially on the sides of those large plates that cover the wheels -- interesting pattern, if there even is one.
#12
Why such large wheels on the drive base?
#13
Our initial design with those sideplates (which are each removable as individual assemblies if we need to repair them away from the robot) involved treads, but due to an engineering mishap, we didn't completely get them right, and at the end of the 4th week we had to give up, and order wheels as a quick replacement, as we were running out of time and we were holding up the other subteams on our drivetrain problems. |
#14
Nice looking bot, Adam.
After PNW, I'd worry a little about the square red plates. I think they are going to get smashed in pretty quickly. Also, how beefy is that red bar across the front? We used the C-channel from the KOP for our similar function, and it was noticably, but not fatally, bent by the end of the tournament. Anyway. Looks pretty. Have a great season. |
#15
The red plates stayed on nicely, as they were securing bumpers to the robot. By our second match at UCF, our red L-bar was destroyed, and we replaced it with some dense PVC (I believe). |
| pic: 379's 2006 Robot Cat 7 | Robocat1 | Robot Showcase | 16 | 05-03-2006 12:20 |
| pic: 222 2006 Robot + Video | team222badbrad | Robot Showcase | 12 | 01-03-2006 00:14 |
| pic: Team 230 2006 Robot: Talon VII | Sam Lipscomb | Robot Showcase | 14 | 28-02-2006 12:26 |
| pic: X-Cats 2006 robot X-O X-Cat | Koko Ed | Robot Showcase | 12 | 27-02-2006 09:39 |
| pic: Team 469's Robot for 2006 pic 2 | Don Wright | Robot Showcase | 10 | 26-02-2006 21:03 |
