Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 01-03-2006, 09:39
TEAM1949 TEAM1949 is offline
FRC #1949
TEAM1949 is an unknown quantity at this point
decoder issue
I have a problem to solve tiil nexr sunday.
We are planing to use the decoder sensor.
when I run a program with it {with a working motor ofcourse} the output is running numbers.
Each whole loop of the Small 21 tooth Sprocket is a value of 136321 or close.
What does those numbers?
can anyone give as an exmaple some numbers he go?
tnx!
Unread 01-03-2006, 10:36
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: decoder issue
tnx!
Hmmm, this question is a little hard to decode By "decoder" are you talking about the gear tooth sensor? Since you are posting in the EasyC section I am assuming you are using the EasyC GearToothTest example. Output from the GetGTSensor is a 'long', but the print output is wrong because of overflow (this from another post).
On another note, I assume you are waiting for the fix-it windows to work on this right?
Unread 03-03-2006, 07:09
FRC #1949
Re: decoder issue
ammmm yeah I forgot to mention that its the gear tooth sensor
but still I didnt understand what are does running numbers ?
Its important till tomorrow so....
Unread 03-03-2006, 19:05
AKA: Dan
Re: decoder issue
Well, again I am assuming your are using the test program, try casting it as a long so that it looks like this:
PrintToScreen ( "Gear tooth count = %ld\n" , (long)geartooth ) ;
That should fix the output so that it makes since to you. I believe you are just having overflow because a long can't be stuffed into an int.
Unread 04-03-2006, 07:02
FRC #1949
Re: decoder issue
Yeah I done that and it works.
Buy mu question from the begining was what are those numbers at all??
Unread 04-03-2006, 13:29
AKA: Dan
Re: decoder issue
Generally, whenever you overflow a variable, it is hard to predict what will happen. In some cases it wraps around, in other cases it flows into unassigned memory addresses. The main thing is that when you get strange output, one of the things to look at is to make sure your variable is cast correctly (which you did).
Unread 04-03-2006, 14:37
FRC #1949
Re: decoder issue
And how to be sure I did it right?
would you give an example please?
Unread 04-03-2006, 16:56
AKA: Dan
Re: decoder issue
well all I can say is that if it is counting right, then you have done it right!
Unread 06-03-2006, 08:31
FRC #1949
Re: decoder issue
You mean counting right or counting at all?
Unread 06-03-2006, 08:38
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: decoder issue
Based on the output it looks like you were using %d to print a long instead of %ld.
Unread 07-03-2006, 14:34
FRC #1949
Re: decoder issue
Nope, sir!
I was using the %ld as it should be.
Heroes of Engineering Comic: Dean is the December Issue Vince Dean Kamen's Inventions 5 01-12-2005 12:00
**FIRST EMAIL**/FIRST Newsletter, 2005 Issue #3 Rich Wong FIRST E-Mail Blast Archive 1 04-10-2005 10:24
FIRST Newsletter - 2004, issue #3 Andy Baker FIRST E-Mail Blast Archive 0 22-09-2004 14:17
**FIRST EMAIL**/FIRST Newsletter, 2004 Issue #2 miketwalker FIRST E-Mail Blast Archive 1 04-06-2004 13:31
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
