Go to Post I design gears and gear boxes for a living. I am HAPPY to write a check and have a solution in mailed to me. - Joe Johnson [more]
Unread 03-03-2006, 22:56
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Camera does not search in autonomous mode after reset
We encountered a problem for the first time today at the regional. It only happens in autonomous mode. Take the robot to the playing field, plug in the backup battery, power on the main battery, press reset on the controller, the camera does not initialize.
I've read other people have encountered the same problem but have not seen anyone have an actual fix.
The camera code is correctly called from autonomous mode and works if the robot is put into user mode then back into autonomous mode (which you obvisously cannot do on the field). We even did this in the pits and left the robot powered on till it was put on the playing field. It worked that time.
We have since found a spot in the code which is called in autonomous mode right before the inner while loop. We are going to try to reset the camera intialization variable there and test it during the finals.
The behavior is the same as if a controller reset does not call the program's static initializers in autonomous mode!
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
How should we call camera tracking functions during autonomous mode? SHerpich Programming 1 15-02-2006 18:33
camera auto mode pwm contention? AL_E Programming 4 24-01-2006 22:10
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
