Go to Post Sometimes at work I fantasize about being a giant bulldozer operator. - AdamHeard [more]
Unread 04-03-2006, 11:44
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Question on 3pt Scoring
What is the ruling on a ball that goes into the 3pt hoop, hits the chains and bounces out?
I am sorry that I have not been following the rules. I have seen it happen on the VCU webcast and I wonder what the rule is and whether the rule is being enforced well.
Thanks,
Joe J.
Team #88, TJ2
Unread 04-03-2006, 11:52
Collin Fultz's Avatar
Collin Fultz Collin Fultz is online now
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Question on 3pt Scoring
The ball has to travel down the chute to score since that is where the scoring counter is. So if a ball bounces out...it doesn't count.
see rule G05
Collin Fultz
Unread 04-03-2006, 20:32
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Also though, as long as the balls stay inside the center goal (let's say they get jammed, whatever), they will still be counted.
If it bounces out for whatever reason, it won't be counted.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 04-03-2006, 20:40
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Thanks,
Joe J.
As others have said, unless it passes down the chute it is not counted.
FIRST swore the chains wouldn't rebound the balls...but they were mistaken.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 04-03-2006, 20:47
AKA: Dr. Joe
FRC #0088 (TJ2)
--Petey
Yes, watching the VCU regional finals, I think I saw a robot shoot 3 in a row that hit the back of the goal and bounced out -- took the steam right out of them.
Joe J.
Team #88, TJ2
Unread 04-03-2006, 21:10
Conor Ryan Conor Ryan is online now
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Joe J.
At NJ i don't think i saw a single shot that was aimed correctly that bounced out. If they are bouncing out then chances are they maybe shooting at an excessive speed, or a really high angle so they may want to check out their exit velocity and slow it down for their own good.
Do you happen to have the match numbers?
Unread 04-03-2006, 21:13
Petey's Avatar
Strategy & Gaming
AKA: Chris Peterson
I'd say that at least once during almost every match with a shooter bot, one ball would go dead on in and then bounce off the chains and out.
I doubt they're shooting at an excessive (re: significantly more than 12 fps) speed. Sometimes they were shot too lightly to push the chains apart, it seemed.
--Petey
Bio:
Unread 05-03-2006, 01:10
Originally Posted by iCurtis
I feel it's a design constraint, and machines should have been designed accordingly.
So they should have given us the part numbers for the chain, or even the chain itself. You can't design a machine unless you know what you need to allow for.
(As a side note, at our test area, we didn't worry about bouncing out. There was a substantial brick wall about two feet behind the opening, so if you didn't hit it just right, the ball would always come flying out. We worried more about ceiling beams.)
Unread 05-03-2006, 07:43
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
While watching the web cast, I noticed that balls bounced back out when shooting hard AND soft - seems kind of weird to have a 12 m/s exit velocity if that velocity doesn't match the acceptable entry velocity (upper and lower limits)
I was really surprised by this issue, and it looked like the chains were closed loops in the video - for some reason I had pictured individual strands of chain.
Anyways - here is an interesting item to consider. According to the detailed drawing (link shown below), the chain frame is not symetrical, if assembled incorrectly (back towards the front, instead of front towards the front), the chains would have been closer to the opening than specified - I hope someone checked that because it could account for the balls bouncing out easier at one regional than at the others.
http://www2.usfirst.org/2006comp/Dra...STALLATION.pdf
Unread 05-03-2006, 11:01
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
I was back-up ball counter on the blue goal at VCU:
Balls were only scored if they stayed in the goal. We had a PVC pipe to prod the balls if they got stuck so they would go down the tube into the trashcan.
One thing I saw was that if teams shot the balls too fast, the first ball would be stopped by the chains but the 2nd ball would hit the 1st and bounce out.
It also seemed like balls shot from an angle stayed in the goal more than balls that were shot straight at the chains.
Unread 05-03-2006, 12:10
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
It might help if FIRST shortens the chains a little. That would reduce the number of balls bouncing out. Or lighten the chains. Plastic chains would probably work a lot better.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Scoring Question. Goten Rules/Strategy 5 08-02-2006 16:16
Question: Can robot block lower goals to prevent scoring? Seems unfair. 456RoboChick Rules/Strategy 1 11-01-2006 20:04
between phase scoring calculation question? psycho7 Rules/Strategy 2 08-01-2006 22:05
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
A question about control system options computhief263 Control System 7 04-02-2004 14:46
