Go to Post How is it that so many team representatives have the time to run up the post count to astronomical levels in a game hint thread, while so few seem to have the time to say thank you for a $6K gift that funds the ability to play the game? - Rich Kressly [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 04-03-2006, 13:31
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Exclamation VCU DISQUALIFICATION!
If any of you are watching the webcast, 1 alliance was just disqualified. I didn't exactly catch why they were disqualified, can someone post the reason here?
Thank You,
Tomasz Bania
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 04-03-2006, 13:33
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: VCU DISQUALIFICATION!
They entered the side goal with their robot. Which is a saftey violation (results in a Dq)
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 04-03-2006, 13:35
AKA: Micro3000x
Lightbulb Re: VCU DISQUALIFICATION!
ok, thats what I thought I heard, but I didn't think that was a disqualification but rather a disable. Oh well.
Tomasz Bania
P.S. That freaks me out as I might be our teams driver and those bumpers easily go under those goals.
Unread 04-03-2006, 13:36
MrBamboo MrBamboo is offline
Lead Designer of #1888 (Plano West)
AKA: Fei
FRC #1888 (Sigma F)
MrBamboo is an unknown quantity at this point
it seems there are a lot of DQ's with robots entering the corner goal. I have one question about this. If our robot puts down a draw bridge to score but it is outside the goal. and then an opposing alliance's robot pushes us from behind therefore shoving our draw bridge into the corner goal. Does that count as breaking the rule as it was non-intentional?
Unread 04-03-2006, 13:38
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I think so, which is why a number of dumper teams have put devices that keep them from being able to fit through.
It couldn't have been a DQ for the alliance, because they're back for the 2nd match. It would have to have been a disable.
Unread 04-03-2006, 13:43
Tim Delles's Avatar
Since 2001.
FRC #0078
No it was a dq. the elimnations are best out of 3. So if you get dq one match you can still play the others.
Unread 04-03-2006, 13:45
Nuttyman54's Avatar
Mentor, Tactician
Ahh, sorry, i had a different conception of DQ. In this case it just means a 0 score for the match?
Unread 04-03-2006, 13:51
Tim Delles's Avatar
Since 2001.
FRC #0078
Yeah. A dq is just for the match.
Unread 04-03-2006, 15:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
It's not a safety violation, the rule is G21:
ROBOT Incursion into the Corner Goal - Incidental incursion into the corner goal that occurs as a result of a ROBOT pushing balls into the goal is permitted, not to exceed a distance of approximately 3 inches. Intentional incursion, for example to use a ball gathering mechanism to drop off balls inside the goal, or extending a portion of the ROBOT through the goal opening to activate the ball counting system, will result in disqualification of the offending ROBOT.
Also, the rule specifically says intentional. So if you get pushed in, it can't be intentional. As long as you're not pushed in more than 3 inches, you're okay. I'll check the Q&A real quick to cinfirm this, though.
Unread 04-03-2006, 15:23
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
SF 1.1 resulted in a DQ for the red alliance due to incursion in the corner goal during autonomous mode. Was that the correct call? Without seeing what exactly happened, I know its difficult to say, but no where in the rules or Q/A is it stated what happens during autonomous incursion. Typically there is a grace period or some sort of minor penalty and temporary disablement if a team breaks a rule during autonomous and not a DQ. Any idea?
Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 04-03-2006, 18:38
Thecandyman Thecandyman is offline
FRC #1823
Thecandyman is an unknown quantity at this point
In our first match at the Pacific Regional, we got pushed by another robot into a corner box while trying to dump balls in and got a 5 point penalty, but not a DQ. This was not in autonomous mode.
Unread 04-03-2006, 20:05
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Actually, I had asked once in the Q/A about incursion into the goal more than 3in... and they said that was a DQ. Didn't give any exceptions for being pushed, etc, which implies that your robot should be designed not to go in more than 3in period. That is a safety violation whether you did it or got pushed.
http://forums.usfirst.org/showthread...ight=incursion
You can bet it's the same in autonomous.
This is interesting, since a safety violation is 10pts. Nowhere in the rules that I can see does it talk about a 5pt penalty for this regardless of how you got in the corner goal.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
Unread 04-03-2006, 22:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
414 was well into the corner goal (interesting considering I don't beleive their autonomous had done that before), at least an inch past the 3 in "barrier". They have an unfolding flap and drops to release all the balls into the corner goal, so that's how they managed to get that far in.
Unread 05-03-2006, 01:08
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Kev
It says right there what happens during autonomous mode, which is the same as driver controlled time.
414 was far enough into the goal that they were over the light panel, which happens to be a more than 3 inches inside the goal. At that point they were potentially interfering with the counting system hence the DQ.
Wetzel
Viva Olancho!
Unread 05-03-2006, 04:04
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Wetzel
It really seems like they (FIRST) could have designed that system better so they wouldn't have to make such a minefield of disqualifications. I know nobody wants to hear more complaining about first, but this is kind of ridiculous.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
ATTENTION VCU REGIONAL PARTICIPANTS! Bytor Regional Competitions 0 30-03-2004 09:59
Serious VCU Fire Joe Matt Chit-Chat 3 26-03-2004 19:04
VCU COMPETITION STATUS ggoldman Regional Competitions 98 07-03-2004 18:54
Can any VCU teams help me?/ VCU thanx DUCKIE Thanks and/or Congrats 0 13-03-2002 10:17
Numbers at VCU Madison Regional Competitions 5 10-03-2002 02:26
