Re: VCU DISQUALIFICATION!
What would you have them do better? Wetzel |
The scoring in the lower goals is counted by a camera (of course with a human back-up in case a robot goes into the goal). There are lights under the goal, with a camera mounted at the top of the player's station. A wire mesh is mounted inside the goal to keep the HP's from reaching over the light (one swipe of a hand across the light and the camera counts 5-7 balls). The 2-3 inch margin teams are given for going into the goals is the space from the outer edge of the goal, to where the camera begins scoring. Anything that crosses that light can be scored by the camera, including a robot. |
FIRST designed a system which allows you 3 inches of space, so follow it. Almost every team at VCU didn't have a problem with it, why should it be changed to help the few that don't follow the rules? This isn't by any measure a new rule. It's been in place for the entire season, you should plan accordingly. In 2004 there were similar rules, that didn't even give those 3 inches.
Just my 2 cents. |
I could flex the center of the polycarbonate about 3/4 inch with my fingers, so a hit by the corner of a robot would flex it even more. It seems to me that a legal bumper system could easily draw a penalty. Any refs out there who could tell me how the 3 inches is determined during game play? Greg |
#7
Presumably, your bumpers wouldn't be ONLY in the section that could go into the goal. if you've got bumpers the entire front of the robot, then that becomes the effective front of the robot, and you can't extend in.
#8
hello all..
Its odd how they DQed us as our robot is'nt even designed to be able to go under the goal. Look at the robot in VCU pictures and you'll see why. When we were told about the DQ were questioned it, but did'nt push the issue. So we lived with it. Luckly we won. I was told that some robots if they hit the goal hard enough were making the camera think that they had passed into the goal...thats the only thing I can think of that might have caused our DQ. |
#9
At NJ we actually had a team that accidently waved their hand in front of the camera when they were getting the ball and that resulted in points for their opponents, and incidentally cost them the match.
#11
If a robot enters the goal so far that the camera could see it, it was very obvious to the scoring system. And yes - a robot counted many more times than a hand. This was another reason for real-time scorekeepers at each goal: not just in case the cameras malfunctioned, but in case something entered the goal that shouldn't have been there. The high scores at VCU were because of camera problems - we restarted the camera software and refocused the cameras and everything worked. |
#12
I Saw only one DQ and a small handful of pentalties for the 3 hours i watched on saturday, thats hardly a "Minefield"! |
#14
As far as I know, there were about two teams at VCU that kept being disqualified. Once you see how far those robots went into that goal, you would see how and why they were disqualified. The cameras are extra sensitive. They could pick up anything that passes through the corner goals.
#15
DQ fo 1610 - Match 75 ???
| ATTENTION VCU REGIONAL PARTICIPANTS! | Bytor | Regional Competitions | 0 | 30-03-2004 09:59 |
| Serious VCU Fire | Joe Matt | Chit-Chat | 3 | 26-03-2004 19:04 |
| VCU COMPETITION STATUS | ggoldman | Regional Competitions | 98 | 07-03-2004 18:54 |
| Can any VCU teams help me?/ VCU thanx | DUCKIE | Thanks and/or Congrats | 0 | 13-03-2002 10:17 |
| Numbers at VCU | Madison | Regional Competitions | 5 | 10-03-2002 02:26 |
