Go to Post Think outside the bot. Find a different regional someplace you never considered before. There's plenty of them. - Koko Ed [more]
Unread 05-03-2006, 21:16
Mr. Steve's Avatar
Mr. Steve Mr. Steve is offline
No relation to Mrs. Steve
#1626 (Falcon Robotics)
Mr. Steve is an unknown quantity at this point
Allowing the Ball into the shooter
One of the things our team has had trouble with is what allows the ball into the shooter. We've been trying to use servos with 4 inch arms, but while that works most of the time, it's not quite ideal.
How does everyone else do it? Pictures?
Falcon Robotics
Unread 05-03-2006, 21:21
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Allowing the Ball into the shooter
We have a rolling axle which compresses the ball so it can't get through unless the axle is spinning.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 05-03-2006, 21:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We use a globe motor with an arm on it, but that was giving us some jamming problems too. A servo does seem a bit small/weak for the job though.
Unread 05-03-2006, 21:27
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
use gravity
shaun
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 05-03-2006, 21:29
John C's Avatar
John C John C is offline
FRC #0075 (RoboRaiders)
Team Role: Driver
John C has a spectacular aura aboutJohn C has a spectacular aura about
we use a 6" wheel chair wheel powered by a globe motor to control the flow of balls into the shooter. it pushes the ball right up to the shooter wheels. it allows us to control the rate of fire to give the shooter wheels time to speed back up in between shots to give us good accuracy.
there is a picture here:
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose
Unread 05-03-2006, 21:30
Mr. Steve's Avatar
Originally Posted by nuggetsyl
use gravity
shaun
Yes, the way it is now, technically gravity is brining the ball into the shooter.
I guess the new question is, how to stop the ball from going into the shooter?
Falcon Robotics
Unread 05-03-2006, 21:41
Cheuk Hung Ng Cheuk Hung Ng is offline
Alumnus
FRC #0492 (Titan Robotics Club)
Cheuk Hung Ng is an unknown quantity at this point
We use a gravity fed chute to hold the balls. At the bottom of the shoot is a small wheel attached to a globe motor to stop the balls from going into the shooter. This allows us to spin the shooter up to full speed, then allow the balls to enter the shooter by running the globe motor and the small wheel attached to it.
#1 in the Northwest: 2001 Silicon Valley Regional Rookie All-Star Award || 2001 Galileo Incredible Play Award || 2002 Southern California Regional Judge's Award || 2002 Pacific Northwest Regional Finalist || 2003 Silicon Valley Regional Entrepreneurship Award || 2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's Award Winners
Unread 05-03-2006, 21:50
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
We are using a gravity feeder with a 3/4 in bore 3 in stroke bimba to control the flow of balls.
Unread 06-03-2006, 02:47
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
What about using 2 plexi plates of some sort? you could make a U slot on either side to let the plates ride on, and then your servo should be strong enough to pull the plexi out of the way. They don't have to be full size, just big enough to not let a ball go though.
Our robot uses a conveyors to pick up balls from the base of the hopper and bring them up to the shooter. Since our shooter design spins up incredibly fast, we simply have the shooter and conveyor tied to the same trigger on the joystick. i think we have less than half a second spin up on our shooter, so the only way a ball wouldn't get launched full distance is if it was directly against wheels before we attempt to launch. Here is a thread with a video of our conveyor in action: http://www.chiefdelphi.com/forums/sh...654#post465654
Unread 09-03-2006, 03:17
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Do you have any problem with impelling the poof balls
We have a gravity fed magazine to get the balls to our elevator. Our elevator is two O-Rings driven by the FP motor/tranny. This allows us to control when the balls are fed into the shooter.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 09-03-2006, 07:27
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
We are using a conveyor belt system which stops just before our wheels grab the ball. As long as you end the conveyor belt at the right time it works great. Pic: http://www.chiefdelphi.com/forums/sh...&highlight=610
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 09-03-2006, 10:31
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Actually they work very well. You might need two if you are looking at a big load though. We did two servos 7" apart with photo sensors in between. We found that under a real bad load the plastic disk we mounted to bent a bit but we strengthened it.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 09-03-2006, 13:03
Lee Lee is offline
FRC #0343 (Metal In Motion)
Lee is on a distinguished road
343's "Cyclone" uses a flat belt driven by a globe motor for the final feed into the shooter. Since our shooter is on top gravity just doesn't work...
Unread 09-03-2006, 13:58
in between teams
AKA: Luke Van Oort
We found our servo to be more than powerful enough. However, when it was disabled at the beginning of a match, it wouldn't fight the balls. So, our first couple in auto sort of dribbled out.
Team 1219: 2009 - Mentor
571 Ball Shooter Video Steve Howland Robot Showcase 2 07-02-2006 11:11
Speed Sensor for Ball Shooter Justin Stiltner Electrical 15 28-01-2006 14:40
Team 1280 Prototype Ball Shooter Shelbykr7 Robot Showcase 8 25-01-2006 09:57
Ball Shooter Squall Rules/Strategy 7 11-01-2005 14:47
Ball Shooter Squall Kit & Additional Hardware 0 11-01-2005 06:52
