#16
Re: VCU DISQUALIFICATION!
What would you have them do better? Wetzel |
#17
The scoring in the lower goals is counted by a camera (of course with a human back-up in case a robot goes into the goal). There are lights under the goal, with a camera mounted at the top of the player's station. A wire mesh is mounted inside the goal to keep the HP's from reaching over the light (one swipe of a hand across the light and the camera counts 5-7 balls). The 2-3 inch margin teams are given for going into the goals is the space from the outer edge of the goal, to where the camera begins scoring. Anything that crosses that light can be scored by the camera, including a robot. |
#18
FIRST designed a system which allows you 3 inches of space, so follow it. Almost every team at VCU didn't have a problem with it, why should it be changed to help the few that don't follow the rules? This isn't by any measure a new rule. It's been in place for the entire season, you should plan accordingly. In 2004 there were similar rules, that didn't even give those 3 inches.
#19
Just my 2 cents. |
#21
I Saw only one DQ and a small handful of pentalties for the 3 hours i watched on saturday, thats hardly a "Minefield"! |
#22
As far as I know, there were about two teams at VCU that kept being disqualified. Once you see how far those robots went into that goal, you would see how and why they were disqualified. The cameras are extra sensitive. They could pick up anything that passes through the corner goals.
#23
At NJ we actually had a team that accidently waved their hand in front of the camera when they were getting the ball and that resulted in points for their opponents, and incidentally cost them the match.
#25
DQ fo 1610 - Match 75 ???
Re: DQ fo 1610 - Match 75 ???
Wetzel |
#27
Example: In match 75 @ VCU when 1137 hit 623 in the side, continued to drive, and eventually flipped 623. edit: post's orginal intent was same, but I thought soap108's post meant they didn't get DQ'ed Last edited by henryBsick : 05-03-2006 at 23:13. |
#28
Yes, they were disqualified. They may have been ranked #1 if they had not been disqualified. Anyway, that disqualification didn't hurt them at all considering that they won the regional. ![]() |
#29
I have noted the following Qualification DQs: match 32 - team 1093 match 63 - team 1467 match 69 - team 587 match 72 - team 1184 match 75 - team 1610 Its kinda interesting that most happened on Saturday. KA-108 |
#30
I could flex the center of the polycarbonate about 3/4 inch with my fingers, so a hit by the corner of a robot would flex it even more. It seems to me that a legal bumper system could easily draw a penalty. Any refs out there who could tell me how the 3 inches is determined during game play? Greg |
| ATTENTION VCU REGIONAL PARTICIPANTS! | Bytor | Regional Competitions | 0 | 30-03-2004 09:59 |
| Serious VCU Fire | Joe Matt | Chit-Chat | 3 | 26-03-2004 19:04 |
| VCU COMPETITION STATUS | ggoldman | Regional Competitions | 98 | 07-03-2004 18:54 |
| Can any VCU teams help me?/ VCU thanx | DUCKIE | Thanks and/or Congrats | 0 | 13-03-2002 10:17 |
| Numbers at VCU | Madison | Regional Competitions | 5 | 10-03-2002 02:26 |
