Go to Post We are all insane aren't we? I just want to build a robot now. :P - Lowfategg [more]
  #31   Spotlight this post!
Unread 05-03-2006, 16:02
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Re: The 8.2 (or 8.3) Battery Voltage Bug
Originally Posted by eugenebrooks
...Either the compiler is not correctly initializing the static variables that are not explicitly initialized, or the memory movement that might be caused by the variable landing in a different segment, the one with explicit inits, caused a memory stomping problem to go away.
The compiler creates a section of code in the binary where all of the static initializers are called. I have always assumed any sort of processor reset would call this block of code before calling main().
Originally Posted by gobeavs
That bug hit us once and disabled us for a round at PNW, but we have found a way to avoid it. When we turn our robot on at the beginning of the round we have someone at the OI looking at the battery voltage to give us a thumbs up or down depending on whether it is showing ~12 or 8.2. If we get 8.2 we just power cycle (not just reset, because that screws up the camera). It saved us at least once later on.
We encountered behavior where the symptom is that the static initializers are not being called by a reset under certain conditions. See the recent thread Camera does not search in autonomous mode after reset for a full description of those conditions.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
  #32   Spotlight this post!
Unread 05-03-2006, 21:00
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
I've been able to successfully cause the 8.2 battery voltage bug to occur on demand by sequentially downloading 2 different versions of code (both based off the default code). I haven't narrowed down the exact cause, but I will see what I can find out tonight and call IFI tomorrow. With a way to reproduce the problem, they will hopefully be able to come up with a fix or workaround.
Mike
  #33   Spotlight this post!
Unread 06-03-2006, 00:42
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
I have some information that may be relevant. There is a problem with the silicon in the PIC chip that involves the interrupts not properly restoring register values upon return. I'm not sure if this could cause the problems you're all reporting, but the possibility exists - it may be this problem that the new libraries are supposed to fix.
You can read about this and other errors in the silicon of this line of chips here: http://ww1.microchip.com/downloads/e...doc/80221b.pdf
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
  #34   Spotlight this post!
Unread 06-03-2006, 08:10
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
At least with Team 95's code (which does use an interrupt handler, but just for the Timer2 and ADC), the new libraries don't fix this problem.
  #35   Spotlight this post!
Unread 06-03-2006, 09:56
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
The new libraries didnt fix are problem. And the only interupts used are with Kevin's code.
  #36   Spotlight this post!
Unread 06-03-2006, 11:02
Happy Birthday! steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
We had this problem too - our workaround was to stop using structures. It seemed that even having a simple struct of a few integers would cause rampant corruption and crashing. I'd suggest that as something to try if you're at your wit's end...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
  #37   Spotlight this post!
Unread 06-03-2006, 11:03
kaszeta's Avatar
I just talked with IFI (and was talking to the same IFI rep that was at BAE), and they are looking at the issue and are going to call me back.
  #38   Spotlight this post!
Unread 06-03-2006, 11:08
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Just FYI, IFI uses the high-priority interrupt for SPI communications between the master and slave processors. You just can't get away from those pesky interrupts <grin>.
-Kevin
Kevin Watson
http://kevin.org
  #39   Spotlight this post!
Unread 06-03-2006, 12:16
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
We were using a struct too, in our auto routines....
Has everyone here with this problem used a struct? It'd be funny if it was something as simple as that, but just checking...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
  #40   Spotlight this post!
Unread 06-03-2006, 12:43
AKA: Dr. Brooks
no team (WRRF)
We were using a struct as well, but I believe that the IFI code
also uses structs. Remember that in an earlier post in this thread
the problem has been demonstrated to occur with the default code.
The problem comes and goes with small changes to your code, so
things like "getting away from structs" might make the problem go,
but it will come back later. Unless there is a decisive cure, the only
way out is the 2005 controller and a squeeze to fit if your code has
gotten too big...
Eugene
  #41   Spotlight this post!
Unread 06-03-2006, 12:46
yoyodyne yoyodyne is offline
AKA: Greg Smith
FRC #0116 (Epsilon Delta)
yoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to beholdyoyodyne is a splendid one to behold
We had this problem crop up at the VCU regional on Friday and it almost cost us a number of matches. Each time, we reverted to some version of old code and at one point made just a few mods to the default code just to get operator control of the drive motors and the herder.
Our code:
Uses a lot of structures with mixed char, int, and long types.
Uses Kevin Watson's serial port code.
Uses Timer 4 interrupt for a 5ms real time clock
Uses Kevin Watson's ADC with 5 analog channels each with a 200Hz rate for a 1KHz timer 2 interrupt
Points to structures and calls routines through pointers
Uses two additional shaft encoder interrupts
Assembles a lot of instrumentation data and sends that to the OI user variables, LED variables, and unused PWM outputs for data logging
Process_data_from_local_IO always runs at least every 10ms - we set a flag if two or more 5ms timer ticks have occured so I don't think this is an excessive loading issue. A printf with multiple arguments will cause this dely, however.
When we removed support for the shaft encoders and yanked out all the code that was not absolutely necessary toward the end of the qualification rounds on Sat the problem went away but it is clear to me that it will come back. Code that was "bad" causing the 8.2 volt problem on Friday night worked first thing Sat morning! (Power was removed for an extended period, however the backup battery was connected overnight) Tried to re-load the same code and it started failing again.
My instincts and experience with these problems is leading me to take a good look at the map file to see if there is something fishy going on with data section allocation. The problem is is that I don't have a "known good" hex/map file to use as a reference. We had no problems until Friday and I was wondering if it was the new IFI libraries but I can see from this thread that the problem can occur with the old libraries.
I posted more details to IFI - waiting for a reply.
If all else fails, I am inclined to trim the code to fit in the 2005 controller - not sure if it is legal to use it yet?
Greg
  #42   Spotlight this post!
Unread 06-03-2006, 12:49
kaszeta's Avatar
No structs here (well, it should've used them, but our team's students are just learning about those things).
  #43   Spotlight this post!
Unread 06-03-2006, 12:51
kaszeta's Avatar
also uses structs.
Indeed, take a look at ifi-aliases.h and the pic18 header files and you'll see that most everything you use for variables provided by IFI is a struct.
  #44   Spotlight this post!
Unread 06-03-2006, 12:55
kaszeta's Avatar
Originally Posted by yoyodyne
Our code:
Our original code was very complex, but by competition we had narrowed it down to code that
  • Uses Kevin's gyro code (which includes his serial code and adc code)
  • Uses Timer2 and the ADC interrupt
  • Uses two analog channels (the gyro and a selector switch for autonomous strategy)
  • No shaft encoders, weird pointers, or anything like that.
(although I like the idea of using a timer to make sure that you aren't bogging down on the loop execution)
  #45   Spotlight this post!
Unread 06-03-2006, 13:30
AKA: Greg Smith
We don't initialize any variables in the code, but instead in each file have an explicit initialize routine such as void InitializeRealTimeClock(void) that performs the initialization. If you write code this way, you don't have to worry about what the loader will or will not do to initialize bss and data. We put all the init calls that were used for autonomous just above the inner loop as well just so we could toggle the competition port pin to test the autonomous routine over and over without hitting reset. - Didn't help with the "8.2" problem though.
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
