Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 06-03-2006, 16:24
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: The 8.2 (or 8.3) Battery Voltage Bug
Originally Posted by yoyodyne
Kevin, we are using v2.40 17 November 2004. I didn't think we were allowed to use any newer versions. Saturday morning I was showing Dave Lavery the problem at the VCU regional and he went over and talked to the "IFI guy" who said that it was not possible for the user processor code to corrupt the battery voltage reading or the RC to OI comms. And that makes sense to me unless memory is shared between the processors or the MP passes the rxdata structure transparently or something like that. Is there any documentation on the interaction between the user processor and the master processor? The only thing I know is the tx and rxdata structures and the format of the dashboard data which provides clues as to what the OTA format between them is. Our one and only 2006 controller is locked in a crate awaiting the Atlanta regional so I can't do any testing but I do have code that parses through the dashboard output and generates an output file I can suck into excel for analysis. I would be interested in what actually comes out of the dashboard port when this is happening to see if data is skewed by a byte or two. I know when we have this problem, control input that should effect PWM5 turns actually gets coupled to PWM1 or 2 (they used to drive the same motor pair) I can give more details if anyone is interested.
Greg
That makes sense, however why didn't we see this last year if the only change was the user processor?
Has anyone tried a master update in case some of the RCs have a corrupted master firmware?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Reading battery voltage in software RbtGal1351 Programming 17 21-10-2007 13:07
How to obtain battery voltage from within EasyC DavidSJohnson Programming 2 14-02-2006 00:05
battery voltage compensation Rickertsen2 Programming 5 17-10-2005 22:12
RC Circuits Melissa Nute Math and Science 3 25-01-2004 05:02
Battery Chargers Neal Probert Electrical 46 16-02-2003 22:31
