pic: When One BaneBots Doesn't Do
Re: pic: When One BaneBots Doesn't Do
That is scary to see the banebots cantilevered like that!
I've heard to many horror stories, from reputable sources, about those trannies disintegrating under "any" side load. Otherwise, the idea is sound....and it looks nice too. |
These trannies caused us more trouble than anything at VCU. At VCU we went to Lowe's to find a viable replacement if our other one failed. Luckily I got the replacement drill gearbox ready if need be, but we didn't need it. No, the replacement drill gearbox that is a simple swap with the FisherPrice motor, is not a Dewalt! If anyone is interested in a gearbox for the FisherPrice motors similar to what several teams use the Dewalt gearboxes for maybe I will create a white paper on the gearboxes we discovered at VCU. |
In supprot of Brad, he and Jeff Olsen with the help of another mentor on our team had a spare FP in ready-to-mount- condition with this new gearbox in a matter of a couple matches' free time. Amazingly simple to do. Brad, you really should look into writing up a white paper for the magic you pulled there.
As far as the Banebots go. If you are going to trust them, trust many of them. example: have backups ready to go for a 5 minute or less swap out. |
One thing my fellow team members forgot to mention is that the BaneBots which failed on us was NOT the one with the huge amount of cantilevered load on it. Our top transmission failed, and that one had very little if any side load on it. So just a warning to teams using the banebots, bring spares or you might be stuck redesigning like us!
#7
In defense of the banebot's transmissions, we used them on both of our roller systems this year (with a properly supported shaft) and never had 1 issue with them. My suspicion to the teams that are having them fail is an incorrect use of them. (cantilevered load, improper alignment, etc) When these gearboxes were designed they were designed with combat robots in mind and i can say with much assurance that when used correctly for the most part they will not fail.
Last edited by Greg Needel : 07-03-2006 at 11:24. Reason: because of greg ross's spelling pointer |
#8
We use an FP/5:1 Banebot tranny combo to power each side of our launcher. Each side of the load is supported, and the BaneBots work great. They are relatively quiet too, once you pack them full of grease.
| pic: 1018 - Pic 5 - TWINS ? ... (or mirrors ?) | Stu Bloom | Robot Showcase | 7 | 18-02-2006 15:17 |
| pic: 1018 - Pic 4 - Welded Chassis | Stu Bloom | Robot Showcase | 17 | 03-02-2006 21:36 |
| pic: River Rage 9 pic | JohnBoucher | Extra Discussion | 2 | 30-10-2005 14:43 |
| Using a computer to control the pic | mikesown | Programming | 6 | 13-09-2005 19:13 |
