Go to Post If you're not trying to make the best possible product given your set of constraints and resources I'm not quite sure what you're doing. - Aren_Hill [more]
Unread 05-03-2006, 14:41
Ctrl Alt Delete's Avatar
Ctrl Alt Delete Ctrl Alt Delete is offline
Code Monkey
AKA: David Weitz
FRC #0177 (Bobcats)
Ctrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to beholdCtrl Alt Delete is a splendid one to behold
Send a message via AIM to Ctrl Alt Delete Send a message via MSN to Ctrl Alt Delete
Too much torque?
How much torque can we have on the motors? I'm looking for a specific gear ratio here. We keeping burning out our clutches. Is there any suggestions?
Life lessons learned at robot:
1.) Never take apart power strips
2.) Sleep is required, but not essential to survival
Failure to abide by these lessons will result in headaches...and flaming pants.
"Here at Bobcat Robotics, we pride ourselves in having 60-table MySQL databases, girlfriend cookies, and a vinyl cutter." -Chris Jelly
Unread 06-03-2006, 15:41
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Re: Too much torque?
Just from experience a gear ratio of 1:3 is enough to round out the clutches in a drive if your drive has some momentum behind it, and you try to reverse it. I also made an arm with a 1:5 gear reduction, and I broke the gear teeth before the clutch rounded out, so it kinda depends more on the amount of momentum your mechanism has.
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 07-03-2006, 01:55
bblack7489 bblack7489 is offline
bblack7489 is an unknown quantity at this point
From my experience the clutches really don't work like they're designed. While they typically fail before the internal motor gears strip, they fail by rounding out (not how a clutch is designed to work). I've found a decent workaround. If you put a drop of super-glue in the clutch connection that takes the short axle, you can reduce the strength of the spring (by either cutting it down or weakening it by over-compressing it) so that the clutch will actually slip internally. I realize none of this answers the original question, but at least when the clutch slips internally, it doesn't lead to failure of the part.
~Ben
